  3. Rod align warning ROD-1055 and ROD-1075
  • Views 10967
MorrisDH
MorrisDH over 4 years ago
Getting rod warnings from pcell layout code and the result is a broken layout.
The pcell compiles with no errors or warnings and an initial placement of the pcell looks perfect. However, while editing parameters I will see the following warnings.
*WARNING* (ROD-1055) rodAlign: Reference object rodObj:808548320 named S0 not in cellView db:0x24cf221a named nmos4
*WARNING* (ROD-1075) rodAlign: command failed in "<lib>/<cell>/layout"
The <cell> is a mos device placed with Inst = dbCreateParamInstByMasterName(... and <lib> is the tech library.
This pcell which instantiates <cell> is not being compiled in the tech library. Don't think that matters.
After placing the mos device and use rodGetObj(Inst) to make a rod object from the instance. I then create two shapes and attempt to align them to the instance.
    gateConnLeft  = rodCreateRect(?cvId cvId ?layer "poly" ?width 0.4 ?length 0.6)
    gateConnRight = rodCreateRect(?cvId cvId ?layer "poly" ?width 0.4 ?length 0.6)
    rodAlign(?alignObj gateConnLeft ?alignHandle "upperLeft"
             ?refObj rodInst ?refHandle "upperLeft" ?xSep 0.17 ?ySep -0.16)
    rodAlign(?alignObj gateConnRight ?alignHandle "upperRight"
             ?refObj rodInst ?refHandle "upperRight" ?xSep -0.17 ?ySep -0.16 )
The intent is simply to align the rectangles at the upper left and right corners on the instance with some offset and it works fine until it does.
After a few edits the warning begins and the rectangle objects appear as if they are being placed and then rotated 90 degrees. It's the strangest thing I've ever seen.
Complete code:
procedure(switchPcell(@key w l nf polyPitch)
  let( ( cvId length width gatePitch fingers drainSourceWidth tfName tfId contactWidth
          con2Poly con2PolyS con2PolyD con2Edge polyRailWidth gateConnWidth gateConnLength
          contact2Edge gateConnLeft gateConnRight totalLength Inst)
    cvId = pcCellView
    ;cvId = geGetEditCellView()
    ; variables generated from parameters
    length = evalstring(l)/1u
    width  = evalstring(w)/1u
    gatePitch = evalstring(polyPitch)/1u
    fingers = evalstring(nf)
    ; derived variables
    drainSourceWidth = gatePitch-length
    ; contact width extracted from technology
    tfName = techGetTechLibName(ddGetObj(cvId~>libName))
    tfId = techOpenTechFile(tfName "tech")
    contactWidth = techGetParam(tfId "contact_width")
    con2Poly = (drainSourceWidth-contactWidth)/2
    polyRailWidth = 0.48
    gateConnWidth = 0.4
    gateConnLength = 0.6
    con2Edge = 0.072
    totalLength = (fingers-1)*gatePitch+2*(con2Edge+contactWidth+con2Poly)+0.18+length
    ; derived or hard-coded variables for nmos4 parameters
    con2PolyS = con2PolyD = sprintf(nil "%gu" con2Poly)
    contact2Edge = sprintf(nil "%gu" con2Edge)
      cvId
     <lib>
     <cell>
     "layout"
      "S0"
      width:0
     "R90"
      1
      list(
        list("w" "string" w)
        list("l" "string" l)
        list("nf" "string" nf)
        list("advlay" "boolean" t)
        list("con2PolyS" "string" con2PolyS)
        list("con2PolyD" "string" con2PolyD)
        list("contToEdge" "string" con2Edge)
      ) ; parameter list
      t
    ) ; place nmos4
    rodInst = rodGetObj(Inst)
    ; create and align gate connections
    gateConnLeft  = rodCreateRect(?cvId cvId ?layer "poly" ?width gateConnWidth ?length gateConnLength)
    gateConnRight = rodCreateRect(?cvId cvId ?layer "poly" ?width gateConnWidth ?length gateConnLength)
    ; create body connections
    rodCreatePath(?cvId cvId ?layer "metal1" ?width 0.16
                             ?pts list(-(polyRailWidth+0.12):-0.37 polyRailWidth+0.12+width:-0.37))
  ) ; let
) ; procedure
Made edits to the above procedure to hide certain info.
  • MorrisDH
    I modified the code to align the gateConns to a refPoint rather than a refObj. Also don't set rodInst since it is no longer need for alignment. That cleared the rodAlign warnings however, I'm still seeing the rod objects appear in very strange places. And they're rotated 90 degrees.
    I then flatten the pcell one level and the rotated objects are not selectable. If I delete the mos device the extraneous shapes disappear also. They seem to be a part of the pcell but there is no way the mos pcell code could create those shapes.
    I'm stumped.
  • MorrisDH
    Fixed it. The mos device that was being instantiated was also setting cvId = pcCellView. Unfortunately cvId was a global variable in the mos device. This was the root cause of the bizarre behavior.
    Problem solved.
    Andrew Beckett over 4 years ago in reply to MorrisDH
    That explains it. I was doing some experiments with a different device from another PDK and changing a few layers, and it was all working for me - but I did wonder whether there was a difference in a cellView somewhere but didn't spot the mistake.
    I did notice a couple of things during my testing. First you have:
    I think it's better to just do tfId=techGetTechFile(cvId) - that's simpler and more robust.
    I also had to fix one of the parameters to the instance:
    ; ANDREW - this was wrong - it failed to create the instance
    ; because of the type mismatch
    ;list("contToEdge" "string" con2Edge)
    list("contToEdge" "string" contact2Edge)
    Since you'd already created the contact2Edge variable as a string, I assume this was just a simple mistake that maybe you''d already corrected.
  • MorrisDH
    MorrisDH over 4 years ago in reply to Andrew Beckett
    The conToEdge is a cdf parameter defined as a string. I need to evaluate the value elsewhere so that is where the other variable, contactToEdge comes in. I confess that it looks a bit clunky.
    Thanks for the tip on techGetTechFile. I'm sure I've used that before but forgot it existed.
    Cheers,
