  3. A function like lastVal but for the y-axis
  • Views 10919
Mohamed Kamal
Mohamed Kamal over 4 years ago
Is there a way to get the value on the y-axis corresponding to the lastVal on the x-axis?
I mean, lastVal gets you the last value on the x-axis... is there a similar function but for the y-axis to get the last value on it?
    You can use value(waveform lastVal(waveform)) or you could use this code: How can I get the first or last X or Y value from a waveform? (you can add them into the calculator using the "fx" button in the…
    You can use value(waveform lastVal(waveform)) or you could use this code: How can I get the first or last X or Y value from a waveform? (you can add them into the calculator using the "fx" button in the calculator or the "+" button in the expression builder).
  • Mohamed Kamal
    Mohamed Kamal over 4 years ago in reply to Andrew Beckett
    Thanks a lot, that's so helpful Slight smile
