  3. How to set Pin text layer base on LSW select layer
  • Views 10697
TonyTang
TonyTang over 4 years ago
Dear,
I want to set a auto pin text layer while create pin on different metal layer.
For example, create pin use "M1:pin" and its pin text layer is "M1:net", since there is a case different layer to one Pin text case. So I can't simply to use "Same As Pin" option in "Set Pin Label Text Style“ form.
Below  is my code, but it is not work on my request. Could you help to let me know the problem?
procedure(setPinText()
 let((layer purpose)
     case(leGetEntryLayer()
             ('("M1" "pin")  layer = "M1" purpose = "net")
             ('("M1_Match" "pin")  layer = "M1" purpose = "net")
             ('("M2" "pin")  layer = "M2" purpose = "net")
             ('("M2_Match" "pin")  layer = "M2" purpose = "net")
             ('("PAA" "pin")  layer = "AA" purpose = "net")
             ('("NAA" "pin")  layer = "AA" purpose = "net")
      );case
hiEnqueueCmd("le0PinSetNameDisplayForm->pinTDLayerName->value = layer")
hiEnqueueCmd("le0PinSetNameDisplayForm->pinTDPurposeName->value = purpose")
leHiCreateChoice0fPin()
);let
);procedure
hiSetBindKey("layout" "Alt<key>p" "setPinText()")
After my test, it can active change on leiDisplayPinNameDisplayForm(), but modied value can't keep to work on create pin form.
My tool version is IC618. thanks for your help!
    Rather than using the hiEnqueueCmd approach, I would instead just use:
    leSetEnv("pinTextSameLayer" nil)
    leSetEnv("pinTextSamePurpose" nil)
    leSetEnv("pinTextLayer" layer)
    leSetEnv("pinTextPurpose" purpose)
    That should work, I think.
  • TonyTang
    TonyTang over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you so much! That is what I want, and it works well,
