  3. Member object is 'nil' after using dbCreateInst in SKILL...
  • Subscribers 152
  • Views 2907
Member object is 'nil' after using dbCreateInst in SKILL script, works fine in CIW
TrumanBurbank
TrumanBurbank over 4 years ago
I am automating the creation of many buffers in my schematic, however, I encounter this error:
buf_cv = dbOpenCellViewByType("techlib" "buffer_name" "symbol")
buf = dbCreateInst(cv buf_cv "test_buffer" list(inx iny) "R0" 1)
println(buf~>instTerms)
Where inx and iny are coordinate values assigned earlier. "techlib" and "buffer_name" are stand-ins for a tsmc standard cell library and the buffer cell. I don't understand why the last line, buf~>instTerms returns nil. If I go to the CIW and select the buffer schematic, and run:
css()~>instTerms
It gives the list of terminal objects as expected. What is causing the discrepancy and what's the solution? Thanks
  • sebcliq
    sebcliq over 4 years ago +1
    You need to explicitly Check and Save when running script ( schCheck + dbSave ) Newest versions of Virtuoso are doing the C&S automatically when schematic changes, so this may explain the discrepancy…
    Andrew Beckett over 4 years ago in reply to sebcliq +1
    Just to clarify what Sebastien says, the database itself does not automatically create instTerms - you'd need to do that yourself with dbCreateInstTerm or dbCreateConn, or call schCheck() to call the schematic…
  • sebcliq
    Sebastien
    Just to clarify what Sebastien says, the database itself does not automatically create instTerms - you'd need to do that yourself with dbCreateInstTerm or dbCreateConn, or call schCheck() to call the schematic extractor/checker. In ICADVM20.1 there is automatic incremental connectivity extraction in the schematic editor (if the schematic is open in the schematic editor) - it's not quite doing an automatic "Check and Save" - it's only doing the connectivity extraction incrementally, and not (yet) the check part (this is on the future plan) and certainly not the save. Even in older releases, the schematic editor tended to auto-add instTerms, but Sebastien is right, you're almost certainly seeing the effects of the editor kicking in.
