  3. How to copy stdVia from lower level cell to top (according...
  • Views 10330
How to copy stdVia from lower level cell to top (according to some area) ?
Charley Chen
Charley Chen over 4 years ago
Hi All,
Hierarchy layout cells and use many stdVia/customVia in each cell , How to copy each stdVia/customVia from bottom to top to a new cell ?
Support  asign bBox (all bBox / assign bBox  )
|---  Top Cell                                                            --->   Top Cell New
| -------A Cell /B Cell  (stdVia : M2_M1/M3_M2...)
|-----------C Cell .(stdVia : M2_M1/M3_M2...)
Thank you very much,
Charley
    Something like this should do it:
    procedure(CCFcopyViasToTopLevel(bBox @key (cv geGetEditCellView())
            (start 0) (stop 32))
        let((hierShape)
            foreach(hierVia dbViaQuery(cv bBox start stop)
                if(listp(hierVia) then
                    hierShape=car(last(hierVia))
                else
                    hierShape=hierVia
                dbCopyFig(
                    hierShape
                    cv
                    dbGetHierPathTransform(hierVia)
            t
    You can then call: CCFcopyViasToTopLevel(geGetEditCellView()~>bBox) to copy all in the top-level cellView's bounding box, or you could give a different area to the function. If you don't want it to copy the top-level vias that are already present, you can pass ?start 1 to the function.
  • Charley Chen
    Charley Chen over 4 years ago in reply to Andrew Beckett
    Hi Andrew ,
    Thank  you very much .
    Charley
