  3. Printing node voltages to excel
  • Views 9110
hdeshmukhnvidia
hdeshmukhnvidia over 4 years ago
Hello all, I wanted to check if we have a utility /skill code to print the node voltages of a selected instance to excel or a text file, if I do save all , cdsTerm data will already be present in psf file, can we somehow parse the file and get all the cdsTerm pin voltages associated with a given instance, this way we can print all the data to a text or excel file by just selecting the instant , we need this so that we can easily document or compare the initial (or any intermediate transient ) state voltages across 2 test bench instances , currently I have to visually check the voltages between to test benches and this process is extremely inefficient and time consuming as the symbols can have >1000 pins.
