  3. Problem with tables
  • Subscribers 150
  • Views 11560
Problem with tables
RicardoGV1
RicardoGV1 over 4 years ago
Hi everybody,
I'm having troubles with a table that is overwriting every Route value within the keys.
In this case I created the keys Skills and SetupSMIC.
as it's shown, first they both have "a" in the Route parameter, then I set SetupSMIC route as "b"
but when printing skill route also get changed
And I created this two keys and they are working correctly
Also I was working with another table like that and I didn't have that problem
the problem are the ones that were created this way, It looks like they have the same memory space.
Does anybody know what I'm doing wrong?
getVersion()->virtuoso version 6.1.8-64b
getVersion("virtuoso")->sub-version IC6.1.8-64b.500.22
Best regards,
R. Gómez
  • AaronSymko
    AaronSymko over 4 years ago +1
    When creating a new DPL, use list(nil) instead of '(nil). In SKILL, using '(nil) in a local scope (i.e. within a procedure) will actually create a global (i.e. statically constructed) DPL. As a result…
    Andrew Beckett over 4 years ago in reply to RicardoGV1 +1
    Just to add a little more to @AaronSymko's explanation, what is happening if you use a quoted list is that the variable (or table in this case) is storing a pointer to the literal list in the code - and…
  • AaronSymko
    In SKILL, using '(nil) in a local scope (i.e. within a procedure) will actually create a global (i.e. statically constructed) DPL. As a result of this, you get data sharing when using '(nil), which is usually not what is intended.
  • RicardoGV1
    RicardoGV1 over 4 years ago in reply to AaronSymko
    Hi AaronSymko,
    Thank you very much for that clarification.
    That worked very well. Slight smile
    Just to add a little more to @AaronSymko's explanation, what is happening if you use a quoted list is that the variable (or table in this case) is storing a pointer to the literal list in the code - and you're not getting a newly allocated list each time the assignment happens to different table entries.
  • RicardoGV1
    RicardoGV1 over 4 years ago in reply to Andrew Beckett
    Thanks Andrew!
