  3. Get user input with GUI in the runtime
  • Views 14261
sbkuizlzl
sbkuizlzl over 4 years ago
Hi all.
I'm using Virtuoso IC6.1.8-500.19 and I am writing the SKILL script that needs to take user's input in the runtime.
At first, I implemented it by using gets function and got the input from CIW. It works well.
However, I want to take the input with GUI.
A trick I can think is that call break to halt the function right after hiDisplayForm, and if the callback is called by clicking "OK", take the value from the form as below.
procedure(test_gui()
    formId = gui_body()
    break()
    want_value = formId-><some_field>->value
);procedure
procedure(gui_body()
prog((formId)
    /* Some field
    formId = hiCreateLayoutForm(... ?callback "continue()" ...)
    hiDisplayForm(formId)
    return(formId)
);prog
);procedure
But I don't think it is a good way. Is there a way to achieve it?
    Using a break() is definitely the wrong thing to do. There are two ways you can do this:
    1. Pass ?dialogStyle 'modal to the hiCreateLayoutForm.
    2. Put the logic you want to do once the form is issued in a function that you call from the ?callback.
    The second is really the right way to do this. If you make the form blocking (the first approach), then unless you change the buttonLayout too, pressing the Apply button won't do what you want (it won't work properly with your break/continue approach either, which will also need a SKILL development license to run).
  • AurelBuche
    AurelBuche over 4 years ago
    Hi, I guess what you just need is the 'modal dialogStyle argument:
    This should do what you expect:
    (defun prompt nil
      "Prompt user, return typed string"
      (let ((form (hiCreateLayoutForm 'custom_prompt "Prompt"
                    (hiCreateFormLayout 'main_layout ?items (list (hiCreateStringField ?name 'input ?prompt "Input")))
                    ?dialogStyle 'modal
                    ?buttonLayout 'OKCancel
                    ?buttonDisabled '(Help)
        (hiDisplayForm form)
        form->input->value))
    Cheers,
    Aurélien
  • sbkuizlzl
    Andrew Beckett and AurelBuche:
    Thank you for your replies! Slight smile
    I agree with you that ?dialogStyle 'modal can be helpful to get the user input while the SKILL script is halted.
    However, in my case, the form should be 'modeless because the user have to check a cellview while it is halted and give some values.
    In other words, while the program is halted, Virtuoso should not be halted.
    Sorry for insufficient information in the prior question.
    More precisely, the toy example that I want to do is as below.
    procedure( my_func()
    let((a)
        form_id = toy_gui()
        a = form_id->str_field->value
        printf("a = %s\n" a)
    );let
    );procedure
    procedure( toy_gui()
    prog((str_field vbox_layout form_id)
        str_field = hiCreateStringField(?name 'str_field)
        vbox_layout = hiCreateVerticalBoxLayout('vbox_layout ?items list(str_field))
        form_id = hiCreateLayoutForm('toy_form "Example" vbox_layout ?buttonLayout 'OKCancel)
        hiDisplayForm(form_id)
        return(form_id)
    );prog
    );procedure
    In this example, what I want to print is "a = <some value that I typed in the GUI>" but this program always print "a = " because the form is modeless.
    So I use the break() and continue() callback trick.
    and Andrew Beckett:
    In the second approach, is there any way to modify value a in my_func() by callback function, while a is a local variable?
  • AurelBuche
    AurelBuche over 4 years ago in reply to sbkuizlzl
    SKILL++ environments/closures are meant for this as I tried to explain in this post: Help me! How to SKILL activation in the background??
    Cheers
    Aurélien
    Andrew Beckett over 4 years ago in reply to AurelBuche
    You could use closures as Aurélien suggested, but it might just be as simple as doing this:
    procedure( toy_cb(form_id)
    let((a)
    	?buttonLayout 'OKCancel ?callback 'toy_cb)
        return(form_id)
    );prog
    );procedure
    Then call toy_gui, and then the callback can retrieve info from the form and make an action. Potentially if it needs to access information from before the form was displayed, that could be stored as properties on the form - but I didn't get that need from your description.
  • sbkuizlzl
    sbkuizlzl over 4 years ago in reply to Andrew Beckett
    Andrew Beckett and AurelBuche :
    Thanks a lot.
    I'll check the posts Aurélien suggests.
