  3. how to print the absolute/relative path from file
  • Replies 8
  • Views 5953
saurabh96
saurabh96 over 4 years ago
Hello I have two setting file....setting file 1 which consists of-
source netlist1                                                    (relative path)
top cell  test21
setting file 2 which consists of-
source /xyz/path1/path2/netlist1                       (absolute path)
top cell  test21
procedure(readSetupFile(form)
  let((prt split removeQuotes commandArg)
    setup_file_path = form->setupFile->value
    removeQuotes=pcreCompile("['\"]")
    unless(blankstrp(form->setupFile->value)
      prt=infile(form->setupFile->value)
      when(prt
        while(gets(line prt)
          split=parseString(line)
          when(stringp(cadr(split))
            commandArgs=pcreReplace(removeQuotes cadr(split) "" 0)
            case(car(split)
              (("source")
                test = parseString(setup_file_path "/")
                test_dir = append1((reverse (cdr (reverse test))) commandArgs)
                netpath = buildString(test_dir "/" )
                form->netlistPath->value = strcat("/" netpath)
              ("topcell"
                form->cell->value=commandArgs
        close(prt)
; dummy form to test
hiCreateLayoutForm(
  'forumForm
  "Forum example"
  hiCreateFormLayout(
    'vbox
    ?items list(
      hiCreateStringField(
        ?name 'setupFile
        ?prompt "Setup File"
        ?callback "readSetupFile(hiGetCurrentForm())"
        ?name 'netlistPath
        ?prompt "Netlist Path"
        ?name 'cell
        ?prompt "Cell"
hiDisplayForm(forumForm)
when i give setting file1 path /xyz/abc/cadence/setting1 then output is comign correct as /xyz/abc/cadence/netlist1.
but when am giving setting file 2  path  /xyz/abc/cadence/setting1 then output is comign incorrect as /xyz/abc/cadence//xyz/path1/path2/netlist1
how to correct so gets the corrrect result.
    Andrew Beckett over 4 years ago in reply to saurabh96 +1
    These two amongst others: ; because of a bug in the forums, I can't paste code calling the right function. So I used specialFunction instead. It should be a function ; which is a single word that begins…
  • mbracht
    mbracht over 4 years ago
    If you expect me to help I need better problem descriptions! What exactly is that script/callback supposed to do in the first place? What do you mean by "output"? That callback's return value maybe? And what is the content of these files? I've been trying to understand your problem for the last 15 mins but to no avail! Not to mention that you keep sending your code without any indentations which renders it unreadable - well at least for me. The less time I need to reproduce your issue the better chance you have that I look into it!
    So please provide a clear problem description and an explanation what I need to do to see the behavior at my end.
    Max
  • saurabh96
    saurabh96 over 4 years ago in reply to mbracht
    Hi Max,
    apologies,
    if you run above code...you will get this
    Now when i give my setting file 1 path which contains
    source netlist1
    top cell  test21
    you will get
    but if if give setting2 file which constains
    top cell  test21
    so the netlist path am getting wrong.
    Hope it clears some clouds.
  • AurelBuche
    AurelBuche over 4 years ago
    I guess what you are looking for is simplifyFilename
    This function takes a path in argument and gives you the fully expanded path
    If you give it your relative path, it will expand it in the current directory, if you give it the full path it will leave it as is
    Hope this help
    Cheers
    Aurélien
    I reformatted your code in the initial post - see it's much easier to read now? Usually you can do this in most browsers by saving the code in a file with a ".txt" suffix and loading it in the browser, and then copying and pasting into the forum (other methods are available if that doesn't work).
    Your "setting" file examples also ought to use "topcell" not "top cell".
    Essentially you'll need to fix the logic in this part of the code:
                  (("source")
    to either check for the path beginning with "/" or to maybe use simplifyFilename. At the moment it is just blindly prepending the path of the set up file to the beginning of the netlist path. If your requirements are different than that, you'll need to write code to perform that different behaviour.
  • saurabh96
    saurabh96 over 4 years ago in reply to Andrew Beckett
    Thanks Andrew,
    Is there any command in skill to check whether the path begins with "/"  like pattern matching.
    ; which is a single word that begins with "sub" and ends in "string" - I just can't enter "substring"
    specialFunction(setup_file_path 1 1)=="/"
    pcreMatchp("^/" setup_file_path)
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    Ah, turns out that it does allow me to use "substring" in quotes. That's the function name I meant to use where specialFunction was. Sorry, if I use the correct function name directly, the forum posting gives an error.
  • saurabh96
    Thank you Andrew :}}
