  3. json to SKILL
  • Subscribers 150
  • Views 12210
json to SKILL
AurelBuche
AurelBuche over 4 years ago
Hi All,
I was wondering if there is a simple way to render JSON into a LISP readable format (i.e. with parentheses so I could use lineread)?
I remember a post from Andrew to convert .xml the same way using xsltproc and a custom stylesheet. I am looking for a similar solution
Cheers
Aurélien
    Hi Aurélien, I've never written one - one of those things I'd get to if I had a burning need. If I was going to write a quick-and-dirty (similar to the xlstproc approach) I'd probably write a simple…
    Hi Aurélien,
    I've never written one - one of those things I'd get to if I had a burning need. If I was going to write a quick-and-dirty (similar to the xlstproc approach) I'd probably write a simple python script to use json.load() to import into a Python dictionary (which can then contain dictionaries and arrays within) and then a recursive function to traverse that and dump it out as an s-expression.
    Of course, it would probably be worth converting one of the common-lisp implementations of a JSON reader into SKILL, but I've not done that either.
    Maybe somebody else has? We have had a few enhancement requests to provide such a function, but they've not made it to the top of the pile yet.
  • AurelBuche
    AurelBuche over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, I guess the Python approach is effectively the simplest according to my javascript skills
    I was looking for jq solutions but I am not sure it is worth learning for this very purpose
    Cheers
    Aurélien
