  3. Sort file-data
  • Views 10310
Sort file-data
Mabr86
Mabr86 over 4 years ago
i have a file with the following content:
7.5 (66.3 13.9)
2.2 (69.75 19.75)
36 (65.45 21.25)
3.3 (65.35 19.9)
7.5 (56.15 25.3)
I want to sort the data based on the number in front. The result should be:
2.2 (69.75 19.75)
3.3 (65.35 19.9)
7.5 (66.3 13.9)
7.5 (56.15 25.3)
36 (65.45 21.25)
Can anyone help me with the code? I tried it with "while(gets(...)" and sortcar, but it doesn´t work because i can´t convert the individual lines into lists.
    Andrew Beckett over 4 years ago in reply to Mabr86 +1
    foreach(line data printf("%L\n" line)) t It all depends on what you're planning to do with the results - a list is a list - it's up to you how you display it. Andrew
    fp=infile("file.txt")
    data=nil
    while(line=lineread(fp)
      data=cons(line data)
    close(fp)
    data=sortcar(data 'lessp)
  • Mabr86
    Mabr86 over 4 years ago in reply to Andrew Beckett
    Thank you! Now the whole list is in one line. Can the list be formatted so that the results are one below the other?
