  3. Inserting a customized toolbar in a layout
  • Views 10414
JRP29
JRP29 over 4 years ago
I am creating a customized toolbar using hiCreateToolbar command and I am using deRegUserTriggers function to insert that toolbar everytime we open a new layout.
But while doing descend  Shift+X  or/and Shift+B, the user trigger is happening which creates the same toolbar agian as a duplicate in the layout window.
Is there any other proper way to insert a customized toolbar in layout window or how to avoid user trigger while descending or return to top level.
Let me know if the question is not clear ,I can explain further.
  • AurelBuche
    AurelBuche over 4 years ago +1
    Hi, I know it is not exactly what you ask for but why don't you just check the toolbar is not already displayed: (defun user_trigger (dpl) (unless (pcreMatchList "my_toolbar_name" (hiGetWindowToolbars…
  • JRP29
    JRP29 over 4 years ago in reply to AurelBuche +1
    Thanks Aurélien for the work around. It is working properly now.
  • AurelBuche
    (defun user_trigger (dpl) (unless (pcreMatchList "my_toolbar_name" (hiGetWindowToolbars dpl->sessionWindow)~>hiToolBarSym) (display_toolbar ...)))
    Something like this should do the job
    Hope this helps,
    Cheers
    Aurélien
  • JRP29
