  3. asiGetPsfDir(asiGetCurrentSession()) do not return ADE assembler...
  • Views 1526
asiGetPsfDir(asiGetCurrentSession()) do not return ADE assembler simulation path for each sweep values
jlaj
jlaj over 4 years ago
Inside ADE assembler i try to save files for each simulation (sweep), use python to perform some computation (python create a file)
Read back this file  to return waveform inside the outputs
To write an read the files i use asiGetPsfDir(asiGetCurrentSession()). And everything seem to work except when i try to plot a waveform
When i tried to plot something ADE assembler try to re-compute everything. And this time
asiGetPsfDir(asiGetCurrentSession()) do not return the same path. The new path do not depends on the number describing the simulation (points)
Interactive.142/1/TEST_1 => after simulation the  Points = 1   and so on
Interactive.142/psf/TEST_1/ => trying to plot
How can i get the correct path ?
JL
    ShawnLogan over 4 years ago
    Dea jlaj,
    I read through your Forum question a few times to try to understand it. Based on what I think I understand a couple of comments follow.
    The directory Interactive.142/psf/TEST_1 is the main results directory for  Interactive.142 and when opened in the Results Browser, can be used to plot all the waveforms in the entire Interactive.142 data base. For example, if your run contained 100 individual corners, the subdirectories of Interactive.142 would be 1, 2, 3,...,100. Each of these will contain the results for a single corner. There was also be a subdirectory "psf" and this contains essentially pointers to all the waveforms in the 100 corners.
    I do not know what specific results and what commands you are issuing to "plot". In the absence pf this, I cannot suggest on the behavior you are observing. What I might suggest is that you save the corner number you are working with prior to trying to plot it. Then, you can refer to the waveform(s) in that specific corner in a plot command. Alternately, write the waveform data to a temporary file from that corner and re-construct it in a new waveform window.
    Sorry I can not provide a more definite set of suggestions jlaj.
    Shawn
