  3. q_copySkipLibList arguments of ccpCopyDesign
  • Views 9970
sbkuizlzl
sbkuizlzl over 4 years ago
Hi all.
I'm using Virtuoso IC6.1.8-500.19 and I want to copy all "maskLayout" cellviews in hierarchy from cellview A to library of cellview B.
So, I write the SKILL script as below.
src = gdmCreateSpec(A->libName A->cellName A->viewName "" "Library")
dest = gdmCreateSpec(B->libName "" "" "" "Library")
ccpCopyDesign(src dest nil 'CCP_NO_EXPAND nil list("maskLayout"))
However, it returns error with the message,
*Error* ccpCopyDesign: argument #5 should be a gdm spec list (type template = "GGgsqllttsqggg") - nil
Could you tell me how can I fix it?
    Two things:
    1. You can't pass CCP_NO_EXPAND to ccpCopyDesign (see the documentation)
    2. For the fifth argument, the documentation is incorrect. It doesn't accept nil if you don't want to give a list of libraries to ignore, but instead you can pass gdmCreateSpecList() - which will then produce an empty spec list.
    I've fed back to our documentation team about the error in the documentation to get this corrected.
  • sbkuizlzl
    sbkuizlzl over 4 years ago in reply to Andrew Beckett
    Thank you, Andrew Beckett!
    It works after I modify
    1. CCP_NO_EXPAND -> CCP_EXPAND_ALL
    2. nil -> gdmCreateSpecList()
