  3. epxt() calculates wrong results - same with pow(), same...
  • Views 2748
epxt() calculates wrong results - same with pow(), same with ** operator
Volker T
Volker T over 4 years ago
I ran a test script using the expt() function, and it gave odd results.
So I typed it directly into CIW command line:
expt(10 12)
=> -727379968
I would expect the answer to be 1000000000000.
It works for a power of 9, though:
expt(10 9)
=> 1000000000
Same happens with other exponents:
for(i -24 24 printf("%g\n" 1.0*expt(10 i)) )
1e-24
1e-23
1e-22
1e-21
1e-20
1e-19
1e-18
1e-17
1e-16
1e-15
1e-14
1e-13
1e-12
1e-11
1e-10
1e-09
1e-08
1e-07
1e-06
1e-05
0.0001
0.001
0.01
0.1
1
10
100
1000
10000
100000
1e+06
1e+07
1e+08
1e+09
1.41007e+09
1.21575e+09
-7.2738e+08
1.31613e+09
2.76447e+08
-1.53049e+09
1.87492e+09
1.56933e+09
-1.48662e+09
-1.98128e+09
1.66199e+09
-5.5994e+08
-1.30443e+09
-1.59384e+08
-1.59384e+09
By the way: 10**12 is also -727379968 accoring to CIW...
Is there a bug?
  • ebecheto
    ebecheto over 4 years ago +1
    expt(10.0 12.0);=> treats numbers as float. Otherwise they are treated as integer. Same behaviour with other programs. Also 1/3 ;=> 0 Whereas 1/3.0 ;=> 0.333 ++
  • ebecheto
    Also 1/3 ;=> 0
  • Volker T
    Volker T over 4 years ago in reply to ebecheto
    Thank you very much!
    I thought I had also tested with expt(10 1.0*i) in my loop and got the same result, but apparently I forgot to save my code before testing again, so no wonder, the same unexpected results came out.
    I checked again, this time with expt(10 1.0*i) and a saved file and it works as expected.
    Andrew Beckett over 4 years ago in reply to Volker T
    Rather than using 1.0*I you can also do float(i) to cast an integer to a float. Or if you just use expt(10.0 i) that would work too. Provided that one of the numbers is a float, it would be fine.
