  3. Replace list elements based on input criteria
  • Views 11673
MorrisDH
MorrisDH over 4 years ago
Example input to the function is a string  "0.0 0.12u -0.12u 0.18u".
What I need is something that will replace any value below 0 with 0 and replace any value above a given maximum to the maximum. For example, if the given maximum in 0.16u then the above example input should return "0.0 0.12u 0.0 0.16u".
I made it work with the following but I'm wondering if there is a better way.
input = "0.0 0.12u -0.12u 0.18u"
threshold = "0.16u"
listInput = parseString(input)
newList = list()
foreach(element listInput
  if(evalstring(element) > evalstring(threshold) element = threshold)
  if(evalstring(element) < 0 element = "0.0")
  newList = append1(newList element)
    For a start, do not use evalstring for this. It's a bad idea - because if your string happened to contain SKILL function calls, it will execute them.
    I would use a foreach mapcar and generalise like this:
    procedure(CCFlimitStringList(strNumList lower upper "ttt")
      let((num (lowerNum aelNumber(lower)) (upperNum aelNumber(upper)))
        buildString(
          foreach(mapcar elem parseString(strNumList)
            num=aelNumber(elem)
            cond(
              (num<lowerNum lower)
              (num>upperNum upper)
              (t elem)
    Then you can use:
    CCFlimitStringList("0.0 0.12u -0.12u 0.18u" "0.0" "0.16u")
    I'm using aelNumber; if this was going to be for use in a PCell, then cdfParseFloatString might be a better alternative. Or even num=car(linereadstring(elem))
  • MorrisDH
    MorrisDH over 4 years ago in reply to Andrew Beckett
    That's beautiful! This is for a pcell callback so the aelNumber is OK.
    I've not used "cond" before. It looks very handy.
    Andrew Beckett over 4 years ago in reply to MorrisDH
    I’m not sure what you mean by a “pcell callback” but assuming you really meant a CDF callback, I’d change it to use cdfParseFloatString - that would be safer.
    Glad it was useful!
  • MorrisDH
    Yes, cdf callback is what I meant. And will follow your advice and replace aelNumber with the cdf command.
