  3. Attempting to Merge Shapes Created by two rodFillWithRe...
  • Subscribers 152
  • Views 10748
Attempting to Merge Shapes Created by two rodFillWithRects
Ynishant
Ynishant over 4 years ago
    I'm creating a polygon and filling it with rectangular shapes that are intersecting with each other. I'd like to merge the shapes created by the rodFillWithRects() function. I'm essentially filling an octagon with intersecting rectangles and would like to merge the rectangles to create a series of larger rectangles. Is it possible to use dbLayerOr() to accomplish this? The code snippet is pasted below and I've also pasted images of what I'd like the end layout to look like:
; the code that follows creates the mesh patterns for the slots
mesh_outside_silox = 1.0
radius = 0.5*w - sil_inset - mesh_outside_silox
D = radius/sqrt(2)
d = 2*D - radius
p9 = list(x+radius y+d)
p10 = list(x+d y+radius)
p11 = list(x-d y+radius)
p12 = list(x-radius y+d)
p13 = list(x-radius y-d)
p14 = list(x-d y-radius)
p15 = list(x+d y-radius)
p16 = list(x+radius y-d)
; outer polygon that forms the template for the waffle pattern
poly3 = rodCreatePolygon(
?layer SLOT
?pts list( p9 p10 p11 p12 p13 p14 p15 p16)
slots_2 = rodFillWithRects(
?shapeId poly3~>dbId
?fillShapeLPP SLOT
?fillShapeWidth sq_x
?fillShapeLength sq_y
?justification "centerCenter"
?spaceX grid
?spaceY sp_y
?enclosureX 0.01
?enclosureY 0.01
?grid grid
slots_3 = rodFillWithRects(
?fillShapeLPP SLOT
?fillShapeWidth sq_x+0.01
?spaceX grid
?spaceY sp_y
?enclosureX 0.01
?enclosureY 0.01
?grid grid
dbLayerOr(cvId SLOT list(slots_1~>dbId) list(slots_2~>dbId))
                                NOW        DESIRED RESULT
  • MorrisDH
    MorrisDH over 4 years ago
    leMergeShapes(setof(shapes geGetEditCellView()~>shapes shapes~>layerName == SLOT))
    If this is for a pcell then this is what I do - there may be a better way.
    merge into another layer
    dbLayerOr(pcCellView "y1" setof(shapes pcCellView~>shapes shapes~>layerName == SLOT))
    delete original shapes
    foreach(obj setof(shapes pcCellView->shapes shapes->layerName==SLOT) dbDeleteObject(obj))
    Change layer of merged shape
    setof(shapes pcCellView~>shapes shapes~>layerName == "y1")~>layerName = SLOT
    SLOT might be an lpp and not a layerName.
  • Ynishant
    Ynishant over 4 years ago in reply to MorrisDH
    Hi Morris,
                    Thank you! This works and was exactly what I was looking for! I was looking for the pCell version, and all I had to do was replace the layerName with lpp and make a few other changes unrelated to the code snippet I pasted.
    Nishant.
