  3. Unable to register data type for csv files
  • Replies 8
  • Subscribers 150
  • Views 12727
MorrisDH
MorrisDH over 3 years ago
This how I coded the DataFormat:
DataFormat libreoffice {
  Pattern = document.csv;
  Default_Editor = libreoffice;
  dfII_ViewType = csvText;
  Co_Managed = document.csv master.tag;
ViewAlias {
  csvText=libreoffice
Tool libreoffice {}
The data trigger:
procedure( csvDataTrigger(argList)
let( (mode(getq(argList accessMode)) libName(getq(argList libName)) cellName(getq(argList cellName)) viewName(getq(argList viewName)) fileId fileName)
    fileId=ddGetObj(libName cellName viewName "document.csv")
    when(fileId
        fileName=strcat(ddGetObjWritePath(ddGetObj(libName cellName viewName)) "/document.csv")
                if(isFile("/bin/libreoffice") then
          ipcBeginProcess(sprintf(nil "libreoffice %s" fileName))
    t
Dummy functions. I don't get why we need dummy functions but that's OK for now.
procedure( csvAppTrig(argL) t )
procedure( csvEnableTrig(@optional argL) t )
procedure( csvRegister()
  deRegApp(
    ?appName "libreoffice"
    ?appTrigger 'csvAppTrig ; Dummy function
    ?dataTrigger 'csvDataTrigger
    ?enableTrigger 'csvEnableTrig ; Dummy function
    ?viewType "csvText"
    ?widgetType "none"
 Register the triggers
csvRegister()
envSetVal("graphic" "viewNameToTypeList" 'string "document csv")
The code loads with no errors or warnings but the view type is not listed in the cell creation drop down.
  • MorrisDH
    Changed "document" to "csvText" in the envSetVal command but that had not affect.
    Manually created the view by created test_csv/csvText/master.tag and test_csv/csvText/document.csv in a library. When I attempted to open in virtuoso I get a warning dialog "The viewType (bom) of cellview Test/test_csv/csvText is not registered to be opened in a Virtuoso window"
    The data.reg file I am using  is the only data.ref file in the search path per setup.loc.
  • mbracht
    mbracht over 3 years ago
    For me this works a treat - I just slightly adjusted the dataTrigger function so as to allow for the scenario that the csv document doesn't exist:
          if(fileId then
          else
             fileId = ddGetObj( libName cellName viewName "document.csv" nil "w" )
             (ipcBeginProcess  (sprintf nil "libreoffice %s" fileName))
          t
    Oh - and I didn't issue the envSetVal statement.
    Max
  • MorrisDH
    MorrisDH over 3 years ago in reply to mbracht
    Does the new view type show up in the "Type" drop down in the "New File" dialog?
  • mbracht
    mbracht over 3 years ago in reply to MorrisDH
    yes it does...
  • mbracht
    Can you please insert some print statement in your data trigger function just to make sure it actually gets called.
    And when you type in the CIW:
    (deGetAllViewTypes)
    do you see you the csvText view type?
    If you do, what do you get from
    (deGetAppInfo "csvtext")
    Max
  • MorrisDH
    How to call the function if I can't create a new cell of that viewType? What does argList look like?
  • mbracht
    argList is a disembodied property list that looks like this:
    from_OpenForm: nil
    fromWindow: nil
    subMaster: nil
    sessionWindow: nil
    checkOutLicense: t
    instanceName: nil
    srcContext: nil
    window: window:4
    pushed: nil
    eip: nil
    action: open
    rootType: "openOffice"
    help: "libreoffice"
    appName: "libreoffice"
    hierPath: ""
    hierarchy: ("{master res doc }:a")
    viewNameList: nil
    accessMode: "a"
    viewFileId: dd:0x2d36e140
    fileName: nil
    viewType: "openOffice"
    viewName: "doc"
    cellName: "res"
    libId: dd:0x2bc655f0
    libName: "master"
    configL: nil
    configId: nil
    prependList: nil
    As you can see it contains (among others...) the information about library, cell and view name.
    But again - can you please run the (deGetAllViewTypes) command to check whether the view type got registered in the first place. And (in case deGetAllViewTypse() returns your new view type) also the (deGetAppInfo ...) command.
    Max
  • MorrisDH
    The data.reg and trigger functions all work now. Unfortunately I'm not sure why. I did modify the trigger function as suggested by mbracht but that initially had no positive affect. Now it's working perfectly.
    Thanks for the help.
    Cheers,
