  3. How to Modify the Corners of polygons inside of pcell
  • Subscribers 152
  • Views 10808
Sorin JIANU
Sorin JIANU over 4 years ago
The beautiful and useful virtuoso function, "leModifyCorner", is not working inside of a source cod of a pcell, because the stream out fails to generate the gds.
How to Modify the Corners of polygons inside of pcell? There are other function?
Thank you in advance for any help.
    If you use PCell Designer, this includes a high level command for doing modifications on corners similar to that provided by leModifyCorner. If writing SKILL PCells, there's no built-in function that does this for you though - you'd have to write something yourself.
    Kind Regards,
  • Sorin JIANU
    Sorin JIANU over 4 years ago in reply to Andrew Beckett
    Thank you Andrew for your prompt answer, less than one hour.
    I'll start to build my own ModifyCorner function, and not loose time to investigate many functions of Huge Virtuoso Documentation.
  • MorrisDH
    MorrisDH over 4 years ago in reply to Andrew Beckett
    Will PCell Designer generate code?
    Andrew Beckett over 4 years ago in reply to MorrisDH
    Yes.
