  3. How to find and print out the pins of schematic using s...
  • Replies 8
  • Subscribers 152
  • Views 17741
How to find and print out the pins of schematic using skill
Drake96
Drake96 over 4 years ago
Hello I have a schematic
How to automatically extract the power and gnd pins in text box..when i select this cell from library browser using skill?
Can you please guide using an example?
  • p94todorov
    p94todorov over 4 years ago
    I am not sure whether this is what you are looking for, but you can get the locations of the pins in a given symbol like this:
    cell = dbOpenCellViewByType("libName" "cellName" "symbol" "schematicSymbol" "r")
    warn("For cell %L, library %L\n" cell->cellName cell->libName)
    foreach(term cell~>signals~>term
        termCenterPt = centerBox(car(term~>pins~>fig)->bBox)
        warn("Terminal %L location X = %n Y = %n\n" term~>name xCoord(termCenterPt) yCoord(termCenterPt))
    );foreach
    This is of course their location in the cellview, in case you need to operate on instances in schematic just transform these coordinates.
    Petar
  • Drake96
    Drake96 over 4 years ago in reply to p94todorov
    Thanks Peter, i tried it but it didn't works...i want the pin names
    suppose for above cell names as i browse it...the power pin and gnd pin should reflect
    as VDD1 GND1
    regards
    Andrew Beckett over 4 years ago in reply to Drake96
    If you want the terminal names of a schematic, use:
    cv=dbOpenCellViewByType(libName cellName "schematic")
    termNames=cv~>terminals~>name
    dbClose(cv)
  • Drake96
    Drake96 over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, is there a way where i can differentiate between power, gnd and io pin and report them simultaneously
    if am using above command...it just list out all pin names
    or any example to understand
    If the Signal Type has been set when the pin was created to "power" or "ground" (this is often automatically set based on the name) - select the pin and do an edit properties on it to check - then you can use this:
      termNames=setof(term cv~>terminals member(term~>net~>sigType '("supply" "ground")))~>name
    (note, the database stores the "power" signal type as "supply").
    This is the only indication in the database as to the intent of the signal - otherwise we have no way of knowing whether something is for power or ground.
  • Drake96
    Thanks Andrew!!!!!
  • Drake96
    Andrew,
    i tried below way-
    but am not getting the desired supply pin in box...apart from that all other options are working fine.
    can you please help me with that
    procedure(abLibCellViewComboExample()
    let((grid lib cell view libLabel cellLabel viewLabel Pwr_Label Pwr_ports
    browse form)
    libLabel=hiCreateLabel(
    ?name 'libLabel ?labelText "Library"
    ?justification 'right
    cellLabel=hiCreateLabel(
    ?name 'cellLabel ?labelText "Cell"
    viewLabel=hiCreateLabel(
    ?name 'viewLabel ?labelText "View"
    lib=ddHiCreateLibraryComboField(
    ?name 'lib ?callback "(ddsUpdateSyncWithForm)"
    cell=ddHiCreateCellComboField(
    ?name 'cell ?callback "(ddsUpdateSyncWithForm)"
    view=ddHiCreateViewComboField(
    ?name 'view ?callback "(ddsUpdateSyncWithForm)"
    Pwr_Label=hiCreateLabel(
    ?name 'Pwr_Label ?labelText "Power Pins*" ?justification 'left
    Pwr_ports=hiCreateStringField(
    ?name 'Pwr_ports ?value "" ?callback "runpwrpin(hiGetCurrentForm())"
    browse=hiCreateFormButton(
    ?name 'browse ?buttonText "Browse..." ?callback "(ddsSyncWithForm (hiGetCurrentForm) 'browse 'lib 'cell 'view)"
    grid=hiCreateGridLayout(
    'grid
    ?items list(
    list( libLabel 'row 0 'col 0)
    list( cellLabel 'row 1 'col 0)
    list( viewLabel 'row 2 'col 0)
    list( lib 'row 0 'col 1)
    list( cell 'row 1 'col 1)
    list( view 'row 2 'col 1)
    list( browse 'row 0 'col 2)
    list( Pwr_Label 'row 3 'col 0)
    list( Pwr_ports 'row 3 'col 1)
    list( 'col_stretch 0 0)
    list( 'col_stretch 1 1)
    list( 'col_stretch 2 0)
    form=hiCreateLayoutForm(
    'abImportParasiticsForm
    "Lib Cell View Pin Example"
    grid
    ?sizePolicy 'horizontalExpanding
    hiInstantiateForm(form)
    ddHiLinkFields(
    form->lib
    form->cell
    form->view
    hiDisplayForm(form)
    procedure(runpwrpin(form)
    let( libName cellName termNames cv)
    libName = form->lib->value
    cellName = form->cell->value
    termNames=setof(term cv~>terminals member(term~>net~>sigType '("supply")))~>name
    form->Pwr_ports->value = termNames
    Drake
    Sorry to be blunt, but I'm amazed after all these questions where you ask questions about implementing UI (both this and under your other account name), you still seem to be unable to do basic debugging. There are a few things wrong here:
    1. The callback is on the Pwr_ports field, which means you have to enter something in that field and then move the focus outside to trigger the runpwrpin function to be called. So you'd type something there, click outside, and then it will run (which would be a rather odd use model). Presumably you would have either a button on the form or have it called once the lib/cell/view are completed (probably not a good idea to do that as it would keep re-reading things as you browse to the right cellView).
    2. Even then, it fails with: *Error* let: local bindings must be a proper list - libName . This is because the let() statement is not correctly written in the callback function (hint, you could test this also by calling runpwrpin(hiGetCurrentForm()) in the CIW).
    3. If I fix the local variable list, it also fails because you're trying to set the value of a string field to a list - termNames will be a list:
      *WARNING* Form 'abImportParasiticsForm', field 'Pwr_ports': Bad value ("VDD1").
      Must be a string.
    Fixing the callback function to be this solves this (a bit of indentation in the code would help, as I keep saying):
    let( (libName cellName termNames cv)
    form->Pwr_ports->value = buildString(termNames)
    Note this still requires you to type something into the "Power Pins*" field and then change focus to trigger the callback; I'm not going to fix your UI code.
