  3. Get blockage and routing layers
  • Views 9941
psill00
psill00 over 4 years ago
How do you get the list of blockage/routing layers listed in the palette Objects?
Paul
  • AurelBuche
    AurelBuche over 4 years ago
    This is probably not the best way to do it but it should do the job:
    (setof lp (techGetTechFile (geGetEditCellView))->lps lp->purpose=="blockage")~>name
    Cheers,
    Aurélien
    Andrew Beckett over 4 years ago in reply to AurelBuche
    Aurélien,
    That is, I believe, how the palette picks them. The LPP info is strictly only needed so that a packet can be defined for the blockage (the blockage objects themselves are not layer-purpose-pairs), but the presence of the LPP is enough for them to show up in the palette. The same is true of the Create->P&R Objects->Blockage, although this can be filtered based on the function of the layer in the tech file.
