  3. How to access variables of one procedure function to other...
  • Views 10974
How to access variables of one procedure function to other procedure function
Sathvik44
Sathvik44 over 4 years ago
I have been trying to access the y and z variables from the pointDone to getPoints and am stuck.
How can I access the y and z variables from point done to getpoints?
procedure(pointDone( w done pts )
if( done then
l=pts
x=car(l)
y=car(x)+0.0
z=car(cdr(x))+0.0
printf("Point entered was %L.\n" pts)
else
println("Point entry aborted.")
list(y z)
enterPoint( ?prompts
list( "Enter a point.")
?doneProc "pointDone"
procedure(getPoints()
printf("%f" ?)
  • mbracht
    mbracht over 4 years ago +1
    Hi, The way you implement your pointDone() function these variables are global so they are accessible from everywhere anyway. But...as you probably know you should avoid global variables whenever you…
  • mbracht
    mbracht over 4 years ago in reply to Sathvik44 +1
    I don't know how to do that...
  • AurelBuche
    AurelBuche over 4 years ago +1
    Hi Sathvik, This cannot be done in classic SKILL but is achievable in SKILL++ Below is an example of what your code could look like Cheers Aurélien inScheme ( ;; Let defining shared variable…
  • mbracht
    The way you implement your pointDone() function these variables are global so they are accessible from everywhere anyway. But...as you probably know you should avoid global variables whenever you can. So the better solution is probably that whatever you want to do with these variables just do it inside the pointDone() function. Since it is a callback function there's no way to capture it's return value.
    Max
  • Sathvik44
    Sathvik44 over 4 years ago in reply to mbracht
    Thank you Max
    I have got to know how to solve my problem.
    Can I know how to delete my discussion/question?
    Sathvik
  • mbracht
  • AurelBuche
    Hi Sathvik,
    Cheers
    Aurélien
    inScheme(
    ;; Let defining shared variable amongst contained procedures
    let( (x y z)
    globalProc(pointDone( w done pts )
    if( done then
    l=pts
    x=car(l)
    y=car(x)+0.0
    z=car(cdr(x))+0.0
    else
    list(y z)
    globalProc(getPoints()
    ;; Here x, y and z variables are the same as `pointDone' ones
    printf("%f" ?)
    ));inScheme
