  3. Issue in Pcell creation
  • Views 9373
Sathvik44
Sathvik44 over 4 years ago
The below code is from Andrew Beckett that I got from one of his posts.
I have made the essential changes based on the technology and palette window.
But I am getting the following error:
Generating Pcell for 'test_pcell2 layout'.
*Error* plus: can't handle (nil + 0.1)
*WARNING* Can't execute procedure 'pcGenCell' to check superMaster.
*WARNING* Pcell evaluation failed. No supermaster was created.
Please let me know where I have done mistake.
Sathvik
; This pcell demonstrates the use of sub-rectangles and offset subpaths
; in the multipart path transistor implementation. The name of the master
; view is:
; pcells step8 layout
; This pcell accepts these parameters:
; width Width of the transistor's active area (note: this is a
; distance measured in the Y-direction).
; (float, default = 3.0)
; length Length of the transistor's active area (note: this is a
; distance measured in the X-direction).
; (float, default = 0.6)
; polyLayer Name of the poly layer.
; (string, default = "poly")
; diffLayer Name of the diffusion layer.
; (string, default = "pdiff")
; contLayer Name of the contact layer.
; (string, default = "cont")
; metalLayer Name of the metal layer.
; (string, default = "metal1")
; drainName Name of the drain connection.
; (string, default = "D")
; gateName Name of the gate connection.
; (string, default = "G")
; sourceName Name of the source connection.
; (string, default = "S")
; sourceContact Whether source contacts should be included
; (boolean, default = t)
; drainContact Whether drain contacts should be included
pcDefinePCell(
; Identify the target cellview.
list(ddGetObj("skill_test") "test" "layout")
; Define formal parameter name-value pairs.
(width 3.0)
(length 0.6)
(polyLayer "POLY1")
(diffLayer "DIFF")
(contLayer "CONT")
(metalLayer "MET1")
(drainName "D")
(gateName "G")
(sourceName "S")
(sourceContact t)
(drainContact t)
; Define the contents of this cellview.
let((tfId polyExtend contWidth polyContSep diffContEnclose
metalContEnclose diffPolyEnclose pinEndOffset polySep transObj grid
polyDiffSep sdWidth)
; convert to proper booleans
sourceContact=(sourceContact==t || sourceContact=="TRUE")
drainContact=(drainContact==t || drainContact=="TRUE")
; Get the technology information for this cell.
tfId = techGetTechFile(ddGetObj("skill_test"))
; Get the minimum extension of poly beyond diffusion.
polyExtend = techGetSpacingRule(tfId "minExtension" polyLayer)
; Get the minimum contact width.
contWidth = techGetSpacingRule(tfId "minWidth" contLayer)
; Get the gate spacing
polySep = techGetSpacingRule(tfId "minSpacing" polyLayer)
; Get the minimum poly to contact spacing.
polyContSep = techGetSpacingRule(tfId "minSpacing" polyLayer contLayer)
; Get the minimum poly to diffusion spacing.
polyDiffSep = techGetSpacingRule(tfId "minSpacing" polyLayer diffLayer)
; Get the minimum diffusion enclosure of contact.
diffContEnclose =
techGetOrderedSpacingRule(tfId "minEnclosure" diffLayer contLayer)
; Get the minimum diffusion enclosure of poly (used when metal contacts
; not included)
diffPolyEnclose =
techGetOrderedSpacingRule(tfId "minEnclosure" diffLayer polyLayer)
; Get the minimum metal enclosure of contact.
metalContEnclose =
techGetOrderedSpacingRule(tfId "minEnclosure" metalLayer contLayer)
; pin end offset
pinEndOffset = -(polyExtend + diffContEnclose - metalContEnclose)
; source/drain width
sdWidth = contWidth+polyContSep+diffContEnclose
; Get the minimum resolution for this process.
grid = techGetMfgGridResolution(tfId)
; Create the gate and diffusion regions.
transObj = rodCreatePath(
?layer list(polyLayer "drawing")
?endType "variable"
?width length
?pts list(0.0:0.0 0.0:width)
?beginExt polyExtend
?endExt polyExtend
; Define the diffusion region - just under the gate
?encSubPath
setof(arg
list(
list(
?layer list(diffLayer "drawing")
?enclosure 0.0
?beginOffset -polyExtend
?endOffset -polyExtend
arg
?offsetSubPath
setof(arg
list(
; Define the drain metal stripe.
when(drainContact
list(
?layer list(metalLayer "drawing")
?pin t
?termName drainName
?justification "left"
?width contWidth + 2.0*metalContEnclose
?sep polyContSep - metalContEnclose
?beginOffset pinEndOffset
?endOffset pinEndOffset
; Define the source metal stripe.
when(sourceContact
list(
?pin t
?termName sourceName
?justification "right"
; Define the diffusion source area
list(
; width depends on whether source contact included or not
?width if(sourceContact sdWidth diffPolyEnclose)
; Define the diffusion drain area
list(
; width depends on whether drain contact included or not
?width if(drainContact sdWidth diffPolyEnclose)
; Define the drain diffusion pin. For abut reasons the pin is
; the same height that the metal pin is
; NOTE - if the difference between diffPolyEnclose and polySep
; is greater than the minimum gate length, then when abutted
; the drain pin from one transistor can short out the
; other transistor. This could be dealt with if necessary by
; making the code a bit smarter
list(
?layer list(diffLayer "pin")
?pin t
?termName drainName
; width adjusts to ensure that the diffusion pins will touch
; when the devices abut
; Define the source diffusion pin. For abut reasons the pin is
list(
?pin t
arg
?subRect
setof(arg
list(
; Define the drain contact array.
when(drainContact
list(
?layer list(contLayer "drawing")
?sep polyContSep
?beginOffset -(polyExtend + diffContEnclose)
?endOffset -(polyExtend + diffContEnclose)
; Define the source contact array.
when(sourceContact
list(
?sep polyContSep
; Define the gate pins.
list(
?layer list(polyLayer "pin")
?pin t
?termName gateName
?width length
?length grid
?space width - 2*grid
arg
rodCreateRect(
?layer contLayer
?width 2.0
?length 3.0
; rodUnNameShape(transObj)
; Dimensions for auto-abutment
; This is fairly simplistic, and in the case of different sized
; devices it can end up with the spacing between gates not quite
; as tight as possible in some cases. However, it demonstrates
; the principle.
; These dimensions are used in the abut function
pcCellView->sameWidthDist=-diffPolyEnclose
pcCellView->diffWidthDist=polyDiffSep-diffPolyEnclose
; Prevent overlap markers
pcCellView->lxBlockOverlapCheck=t
; Add auto-abutment properties
foreach(pin dbFindTermByName(pcCellView "S")->pins
pin->fig->abutFunction="abAbutFunction"
pin->fig->abutAccessDir='("right")
foreach(pin dbFindTermByName(pcCellView "D")->pins
pin->fig->abutAccessDir='("left")
