  3. How to take a screen capture for complete schematic view...
  • Views 14829
How to take a screen capture for complete schematic view in batch mode because I have many schematic views need do it
zsummer
zsummer over 4 years ago
we can use hiWindowSaveImage, hiExportImage, hiExportImageDialog to take a screenshot for schematic view,
but it must work in graphical mode, it means that you must open schematic firstly.
hiGeneratethumbnails can be used to batch mode without open schematic window.
but after check created png file, it missing all port/pin information.
so, I want to know how to take a screen capture for complete schematic view in batch mode because I have many schematic views need do it.
Thanks in advance.
    This should work:
    hiGenerateThumbnails(?lib "opamp090" ?cell "adc_sample_hold" ?view "schematic" ?sizes list(list(1024 768)) ?filePath "adc_sh.png")
    This will generate a file called adc_sh.png in the working dir with 1024x768 pixels. It includes the pins - as you can see:
  • zsummer
    zsummer over 4 years ago in reply to Andrew Beckett
    Hi, Andrew,
    Thanks for your reply firstly.
    my case is like this:
    when I insert a  nand2 stdcell symbol  in schematic, I can see there are A0 and A1 text inside the symbol.
    but after I use hiGenerateThumbnails export this schematic view to a 1.png,
    and then open 1.png, I found there are no A0 and A1 text inside the symbol.
    Andrew Beckett over 4 years ago in reply to zsummer
    You may need to just export with greater resolution. I doubled the resolution here:
    hiGenerateThumbnails(?lib "opamp090" ?cell "adc_sample_hold" ?view "schematic" ?sizes list(list(2048 768*2)) ?filePath "adc_sh.png")
    and you can see this now is showing the labels on the components in my schematic:
    Essentially there's a limit at which small text gets omitted when schematics are drawn, and that may be what is affecting you here.
  • zsummer
    Hi, Andrew,
    unfortunately, I have tried adjust size to 2048 even 4096, but still cannot view any pin name after exported *.png.
    my operation:  create a new cellview 'a/b/schemaitc' -> insert only a top block symbol(eg: tx/dac_top/symbol) -> check and save -> hiGenerateThumbnails(?lib "a" ?cell "b" ?view "schematic" ?sizes list(list(2048 768*2)) ?filePath "a_b_sch.png") ,
    after open a_b_sch.png, it still cannot view any pin name inside tx/dac_top/symbol.
    I have also tried hiGenerateThumbnails(?lib "tx" ?cell "dac_top" ?view "symbol" ... "symbol.png"), open symbol.png, also cannot see any pin name inside symbol.
    Could you help to try insert only a top block symbol not some of single device?
    many thanks.
