  3. hiLayerGen skill implementation
  • Views 8986
GabrielVarela
GabrielVarela over 4 years ago
Hi!
I'm working in a skill code that needs to generate a custom layer as the Layer Generation tool that is already implemented in cadence. I need a similar implementation without the form to generate automatically a metal keep out layer that excludes certain shapes. Any help would be appreciated.
    There are three families of functions: leLayer* functions - these are equivalent to the layer generation tool, and accept layer-purpose names as arguments and process everything on those layers dbLayer…
    1. leLayer* functions - these are equivalent to the layer generation tool, and accept layer-purpose names as arguments and process everything on those layers
    2. dbLayer* functions - these take lists of objects (so you don't have to process the entire layer)
    3. abeLayer* functions - these support shapes throughout the hierarchy and allow you to process them without necessarily generating new shapes. They are limited to octilinear (i.e. multiples of 45 degrees) shapes
    Probably the dbLayer functions are what you want.
  • GabrielVarela
    GabrielVarela over 4 years ago in reply to Andrew Beckett
    Thank you for your help, this solved my problem
