  3. Ocean Script to get Monte Carlo Iteration ID/Directory
  • Subscribers 152
  • Views 2324
zzhu
zzhu over 4 years ago
I have Ocean script called in Explorer/Assember output, in  this ocean script, I check all the sram bits are written correctly or not, then output "Correct" or "Incorrect" in Explorer/Assember output panel. The script seems work OK for one corner. But for Monte Carlo simulation, I would like to get Carlo iteration ID and write it into a file with iteration ID in the name, so what is the Ocean syntax to acheve this? Also, what is the Ocean syntax to get the /psf directory for each iteration run?
    ShawnLogan over 4 years ago
    Dear zzhu,
    I may not understand your act question, but I do use ocean to access results from a Monte-Carlo simulation submitted with Explorer/Assembler as well as conventional corner simulations. The database structure for a Monte-Carlo simulation differs from that for a conventional corner simulation. Hence. a slightly difference algorithm is required to traverse its data than for a conventional corner simulation. The directory structure for a Monte-Carlo simulation is outlined at the On-line support portal at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000005cdJYEAY&pageName=ArticleContent
    I have attached an example of an ocean script that traverses this type of database of it is of any use. The script uses a variable called sim_case_delta to probe the data in each of the subsets of the directory structure. I had to change its extension from ".ocn" to ".txt"  in order to upload it.
    Shawn
    Fullscreen mc_params_112921.txt Download
    load("/home/smlogan/ocean_files/integrate.il")
    load("/home/smlogan/ocean_files/rise_fall.il")
    load("/home/smlogan/ocean_files/delay.il")
    load("/home/smlogan/ocean_files/setup.il")
    load("/home/smlogan/ocean_files/hold.il")
    load("/home/smlogan/ocean_files/duty_cycle.il")
    load("/home/smlogan/ocean_files/skew.il")
    load("/home/smlogan/ocean_files/tap_spacing.il")
    load("/home/smlogan/ocean_files/getWave.il")
    load("/home/smlogan/ocean_files/find_netlist_param.il")
    load("/home/smlogan/ocean_files/check_for_input_scs.il")
    print_internal_nodes_file = 0
    ; Interative directory number
    montecarlo_num = 0
    sprintf(montecarlo_num_val "%d" montecarlo_num)
    ; Main routine
    simulator('spectre)
    date = strcat("040822")
    circuit_name = strcat("sdtal5_TB_test_com_vco_div_smlogan_ftc_sdd5e_com_vco_div_rc_cworst_v1p2_v1p1_slowhigh_m40_0p72_16g_mc_sel_div_0")
    base_results=strcat("/scratch/noclean/dcd_serdes/smlogan/Modules/sdtal5/smlogan_unixrnd.lvn_dev/simulation/sdtal5_TB/test_com_vco_div_smlogan_lvn//maestro_mc/results/maestro/MonteCarlo." montecarlo_num_val "/")
    sub_dir = strcat("/sdtal5_TB_test_com_vco_div_smlogan_ftc_sdd5e_com_vco_div_rc_cworst_v1p2_v1p1_slowhigh_m40_0p72_16g_mc_sel_div_0/groupRunDataDir/psf/mc1_separate/")
    sub_netlist_dir = strcat("/sdtal5_TB_test_com_vco_div_smlogan_ftc_sdd5e_com_vco_div_rc_cworst_v1p2_v1p1_slowhigh_m40_0p72_16g_mc_sel_div_0/groupRunDataDir/")
    TSTOP = 12e-09
    analysis_int = 4e-09
    ; Define clip times
    clip_start = TSTOP - analysis_int
    clip_stop = TSTOP
    ; Set small time period before and after cross times to compute freuqency
    delta_t = 1e-12
    init_val = 1
    final_val = 200
    ;final_val = 4
    sim_case = init_val
    sim_case_delta = 3
    while( sim_case < (final_val + 1)
    printf("sim_case = %d\n" sim_case)
    sprintf(sim_case_val "%d" sim_case)
    sub_sim_case = sim_case
    while( (sub_sim_case < (sim_case + sim_case_delta)) && (sub_sim_case < (final_val + 1))
    sprintf( sub_sim_case_val "%03d" sub_sim_case)
    printf( "sub_sim_case = %03d\n" sub_sim_case)
    results=strcat( base_results sim_case_val sub_dir sub_sim_case_val )
    printf("Results directory\n%s\n" results)
    netlist_dir = strcat( base_results sim_case_val sub_netlist_dir "netlist")
    printf("Netlist directory\n%s\n" netlist_dir)
    ; Check for existence of input.scs file in netlist directory
    ; Returns a "1" if the input.scs file exists and a "0" otherwise
    ; Returns are integers
    if( (check_for_input_scs(netlist_dir) == 1)
    then
    printf("Simulation case %d has valid input.scs file.\n" sub_sim_case)
    ;results=strcat( base_results sim_case_val sub_dir "psf")
    ;printf("Results directory\n%s\n" results)
    ;netlist_dir = strcat( base_results sim_case_val sub_dir "netlist")
    ; Find process case from netlist
    ; find_netlist_param( param_string column_number netlist_dir)
    process_case = find_netlist_param( "section" 2 netlist_dir)
    printf("process_case:\n%s\n" process_case)
    vdda_val = find_netlist_param( "vdda_val" 4 netlist_dir)
    printf("Initial value of vdda: %s\n" vdda_val)
    vdda_val = atof(vdda_val)
    printf("Initial float value of vdda: %.0f mV\n" vdda_val/1e-03)
    openResults(results)
    selectResult('tran)
    ;ocnPrint(?output "outputs.txt" outputs())
    ; Find vdda and temperature
    vdda_val = VAR("vdda_val")
    printf("vdda = %.0f mV\n" vdda_val/1e-03)
    sim_temp = VAR("temp")
    printf("sim_temp = %.0f C\n" sim_temp)
    ; Find freq_GHz
    freq_GHz = VAR("freq_GHz")
    printf("freq_GHz = %0.1f\n" freq_GHz)
    ; Find num_periods
    num_periods = VAR("num_periods")
    printf("num_periods = %.0f input clock periods of %.4f GHz\n" num_periods freq_GHz)
    ; Find sel_div_val_variable
    sel_div_val_variable = VAR("sel_div_val")
    printf("sel_div_val_variable = %0.0f\n" sel_div_val_variable)
    ; Compute number of divout output clock periods
    sel_div_val = if(sel_div_val_variable == 0.0 1.0 sel_div_val)
    sel_div_val = if(sel_div_val_variable == 1.0 2.0 sel_div_val)
    sel_div_val = if(sel_div_val_variable == 2.0 3.0 sel_div_val)
    sel_div_val = if(sel_div_val_variable == 3.0 4.0 sel_div_val)
    sel_div_val = if(sel_div_val_variable == 4.0 1.5 sel_div_val)
    sel_div_val = if(sel_div_val_variable == 5.0 5.0 sel_div_val)
    divout_num_periods = num_periods/sel_div_val
    printf("divout_num_periods = %.0f output clock periods of %.4f GHz\n" num_periods freq_GHz/sel_div_val)
    ; Find tstop
    TSTOP = VAR("tstop")
    printf("TSTOP = %0.3f ns\n" TSTOP/1e-09)
    vdda  = getWave("vdda" "tran" results)
    ave_vdda = average(vdda)
    vth = 0.50*ave_vdda
    clkin1p = getWave("clkin1p" "tran" results)
    clkin1n = getWave("clkin1n" "tran" results)
    clkin1 = clkin1p - clkin1n
    freq_in = if(frequency(clkin1) frequency(clkin1) 0.0)
    clk_p = getWave("clk_p" "tran" results)
    clk_n = getWave("clk_n" "tran" results)
    clk_ = clk_p - clk_n
    ; Adds and subtracts delta_t to avoid error with crossing threshold
    clip_start_clk_p = cross(clk_p vth 2 "rising" nil nil nil) - delta_t
    clip_end_clk_p = cross(clk_p vth -2 "rising" nil nil nil) + delta_t
    clip_start_clk_n = cross(clk_n vth 2 "rising" nil nil nil) - delta_t
    clip_end_clk_n = cross(clk_n vth -2 "rising" nil nil nil) + delta_t
    clip_start_clk_p = if(clip_start_clk_p clip_start_clk_p 0.0)
    clip_end_clk_p = if(clip_end_clk_p clip_end_clk_p tstop)
    clip_start_clk_n = if(clip_start_clk_n clip_start_clk_n 0.0)
    clip_end_clk_n = if(clip_end_clk_n clip_end_clk_n tstop)
    if(clip_start_clk_p > 10.0/(1e9*freq_GHz) 0.0 clip_start_clk_p)
    if(clip_end_clk_p < 10.0/(1e9*freq_GHz) TSTOP)
    clk_p_clipped = clip( clk_p clip_start_clk_p clip_end_clk_p)
    clk_n_clipped = clip( clk_n clip_start_clk_n clip_end_clk_n)
    freq_clk_p = if(frequency(clk_p_clipped) frequency(clk_p_clipped) 0.0)
    freq_clk_n = if(frequency(clk_n_clipped) frequency(clk_n_clipped) 0.0)
    divout_p = getWave("divout_p" "tran" results)
    divout_n = getWave("divout_n" "tran" results)
    divout = divout_p - divout_n
    clip_start_divout_p = if(cross(divout_p vth -(divout_num_periods - 12) "rising" nil nil nil) > 10.0/(1e9*freq_GHz) 5e-09 (cross(divout_p vth -(divout_num_periods - 12) "rising" nil nil nil) - delta_t))
    clip_end_divout_p = if(cross(divout_p vth -2 "rising" nil nil nil) < 10.0/(1e9*freq_GHz) tstop (cross(divout_p vth -2 "rising" nil nil nil) + delta_t))
    clip_start_divout_p = if(clip_start_divout_p clip_start_divout_p 0.0)
    clip_end_divout_p = if(clip_end_divout_p clip_end_divout_p tstop)
    printf("clip_start_divout_p = %.3f ns, clip_end_divout_p = %.3f ns.\n" clip_start_divout_p/1e-09 clip_end_divout_p/1e-09)
    divout_p_clipped = clip( divout_p clip_start_divout_p clip_end_divout_p)
    freq_divout_p = if(frequency(divout_p_clipped) frequency(divout_p_clipped) 0.0)
    clip_start_divout_n = if(cross(divout_n vth -(divout_num_periods - 12) "rising" nil nil nil) > 10.0/(1e9*freq_GHz) 5e-09 (cross(divout_n vth -(divout_num_periods - 12) "rising" nil nil nil) - delta_t))
    clip_end_divout_n = if(cross(divout_n vth -2 "rising" nil nil nil) < 10.0/(1e9*freq_GHz) tstop (cross(divout_n vth -2 "rising" nil nil nil) + delta_t))
    clip_start_divout_n = if(clip_start_divout_n clip_start_divout_n 0.0)
    clip_end_divout_n = if(clip_end_divout_n clip_end_divout_n tstop)
    ;clip_start_divout_n = if(cross(divout_n vth -(divout_num_periods - 12) "rising" nil nil nil) (cross(divout_n vth -(divout_num_periods - 12) "rising" nil nil nil) - delta_t) 5e-09)
    ;clip_end_divout_n = if(cross(divout_n vth -2 "rising" nil nil nil) (cross(divout_n vth -2 "rising" nil nil nil) + delta_t) tstop)
    ;clip_start_divout_n = cross(divout_n vth -(divout_num_periods - 12) "rising" nil nil nil) - delta_t
    ;clip_end_divout_n = cross(divout_n vth -2 "rising" nil nil nil) + delta_t
    divout_n_clipped = clip( divout_n clip_start_divout_n clip_end_divout_n)
    freq_divout_n = if(frequency(divout_n_clipped) frequency(divout_n_clipped) 0.0)
    printf("clip_start_divout_n = %.3f ns, clip_end_divout_n = %.3f ns.\n" clip_start_divout_n/1e-09 clip_end_divout_n/1e-09)
    ; Overwrite TSTOP to minimum value of clip_end_divout_p and clip_end_divout_n to allow for incomplete simulations
    TSTOP = if((clip_end_divout_p > clip_end_divout_n) clip_end_divout_n clip_end_divout_p)
    ; Find currents
    ;ivdda = getWave("ivdda:in" "tran" results)
    ivdda = getWave("/ivdda/PLUS" "tran" results)
    printf("Completed reading waveforms.\n")
    ave_ivdda_mA = if(freq_clk_p == 0.0 0.0 1e3*average(clip(ivdda clip_start_divout_p clip_end_divout_p)))
    ave_pwr_uW = ave_ivdda_mA*ave_vdda/1e-03
    ; clip_start_tpd = cross(clk_p vth -12 "falling" nil nil nil) - delta_t
    ; clip_end_tpd = cross(clk_p vth -2 "falling" nil nil nil) + delta_t
    ; printf("Propagation delay clip time from %.3f ns to %.3f ns.\n" clip_start_tpd/1e-09 clip_end_tpd/1e-09)
    ; tpd_divout_p_rising = delay_ps(clk_p "rising" divout_p "rising" ave_vdda clip_start_tpd clip_end_tpd)
    ; tpd_divout_p_falling = delay_ps(clk_p "falling" divout_p "falling" ave_vdda clip_start_tpd clip_end_tpd)
    ; tpd_divout_n_rising = delay_ps(clk_n "rising" divout_n "rising" ave_vdda clip_start_tpd clip_end_tpd)
    ; tpd_divout_n_falling = delay_ps(clk_n "falling" divout_n "falling" ave_vdda clip_start_tpd clip_end_tpd)
    ; printf("Completed propagation delay time computations.\n")
    if((sub_sim_case == init_val) then
    ; Define output file for simulation results and write header
    sprintf(fname "%s_params_%s.csv" circuit_name date)
    fp_params = outfile( fname "w")
    fprintf(fp_params "Corner number,Process,vdda (mV),Temperature (C),")
    fprintf(fp_params "Desired divider,")
    fprintf(fp_params "Input clock frequency (GHz),")
    fprintf(fp_params "clk_p frequency (GHz),")
    fprintf(fp_params "clk_n frequency (GHz),")
    fprintf(fp_params "divout_p frequency (GHz),")
    fprintf(fp_params "divout_n frequency (GHz),")
    fprintf(fp_params "Divider ratio: divout_p,")
    fprintf(fp_params "Divider ratio: divout_n,")
    fprintf(fp_params "Duty cycle error clk_p (%%),")
    fprintf(fp_params "Duty cycle error clk_n (%%),")
    fprintf(fp_params "Duty cycle error divout_p (%%),")
    fprintf(fp_params "Duty cycle error ave divout_p (%%),")
    fprintf(fp_params "Duty cycle error min divout_p (%%),")
    fprintf(fp_params "Duty cycle error max divout_p (%%),")
    fprintf(fp_params "Duty cycle error divout_n (%%),")
    fprintf(fp_params "Duty cycle error ave divout_n (%%),")
    fprintf(fp_params "Duty cycle error min divout_n (%%),")
    fprintf(fp_params "Duty cycle error max divout_n (%%),")
    fprintf(fp_params "P/N skew clk (rising) (ps),")
    fprintf(fp_params "P/N skew clk (falling) (ps),")
    fprintf(fp_params "P/N divout (rising) (ps),")
    fprintf(fp_params "P/N divout (falling) (ps),")
    fprintf(fp_params "clk_p Rise time (ps),")
    fprintf(fp_params "clk_p Fall time (ps),")
    fprintf(fp_params "clk_n Rise time (ps),")
    fprintf(fp_params "clk_n Fall time (ps),")
    fprintf(fp_params "divout_p Rise time (ps),")
    fprintf(fp_params "divout_p Fall time (ps),")
    fprintf(fp_params "divout_n Rise time (ps),")
    fprintf(fp_params "divout_n Fall time (ps),")
    ; fprintf(fp_params "tpd_clk_p_rising_divout_p_rising (ps),")
    ; fprintf(fp_params "tpd_clk_p_falling_divout_p_falling (ps),")
    ; fprintf(fp_params "tpd_clk_n_rising_divout_n_rising (ps),")
    ; fprintf(fp_params "tpd_clk_n_falling_divout_n_falling (ps),")
    fprintf(fp_params "Supply current (mA),")
    fprintf(fp_params "Power (uW)\n")
    printf("sim_case = %d, sel_div_val = %.4f\n" sub_sim_case sel_div_val)
    fprintf(fp_params "%d,%s,%.0f,%.0f,%.4f," sub_sim_case process_case vdda_val/1e-03 sim_temp sel_div_val)
    fprintf(fp_params "%1.8e," freq_in/1e9)
    fprintf(fp_params "%1.8e," freq_clk_p/1e9)
    fprintf(fp_params "%1.8e," freq_clk_n/1e9)
    fprintf(fp_params "%1.8e," freq_divout_p/1e9)
    fprintf(fp_params "%1.8e," freq_divout_n/1e9)
    fprintf(fp_params "%1.8e," freq_clk_p/freq_divout_p)
    fprintf(fp_params "%1.8e," freq_clk_n/freq_divout_n)
    printf("Averaging clk_p/clk_n between %.3f ns/%.3f ns and %.3f ns/%.3f ns.\n" clip_start_clk_p/1e-09 clip_start_clk_n/1e-09 clip_end_clk_p/1e-09 clip_end_clk_n/1e-09)
    printf("Averaging divout_p/divout_n between %.3f ns/%.3f ns and %.3f ns/%.3f ns.\n" clip_start_divout_p/1e-09 clip_start_divout_n/1e-09 clip_end_divout_p/1e-09 clip_end_divout_n/1e-09)
    du_ave_divout_p = average(dutyCycle(clip(divout_p clip_start_divout_p clip_end_divout_p) ?mode "user" ?threshold vth ?xName "time" ?outputType "plot"))
    du_ave_divout_p = if(du_ave_divout_p du_ave_divout_p 0.0)
    du_min_divout_p = ymin(dutyCycle(clip(divout_p clip_start_divout_p clip_end_divout_p) ?mode "user" ?threshold vth ?xName "time" ?outputType "plot"))
    du_min_divout_p = if(du_min_divout_p du_min_divout_p 0.0)
    du_max_divout_p = ymax(dutyCycle(clip(divout_p clip_start_divout_p clip_end_divout_p) ?mode "user" ?threshold vth ?xName "time" ?outputType "plot"))
    du_max_divout_p = if(du_max_divout_p du_max_divout_p 0.0)
    du_ave_divout_n = average(dutyCycle(clip(divout_n clip_start_divout_n clip_end_divout_n) ?mode "user" ?threshold vth ?xName "time" ?outputType "plot"))
    du_ave_divout_n = if(du_ave_divout_n du_ave_divout_n 0.0)
    du_min_divout_n = ymin(dutyCycle(clip(divout_n clip_start_divout_n clip_end_divout_n) ?mode "user" ?threshold vth ?xName "time" ?outputType "plot"))
    du_min_divout_n = if(du_min_divout_n du_min_divout_n 0.0)
    du_max_divout_n = ymax(dutyCycle(clip(divout_n clip_start_divout_n clip_end_divout_n) ?mode "user" ?threshold vth ?xName "time" ?outputType "plot"))
    du_max_divout_n = if(du_max_divout_n du_max_divout_n 0.0)
    printf("Completed frequency and divider ratio computations.\n")
    fprintf(fp_params "%1.8e," du(clk_p ave_vdda clip_start_clk_p clip_end_clk_p) - 50.0)
    fprintf(fp_params "%1.8e," du(clk_n ave_vdda clip_start_clk_n clip_end_clk_n) - 50.0)
    fprintf(fp_params "%1.8e," du(divout_p ave_vdda clip_start_divout_p clip_end_divout_p) - 50.0)
    fprintf(fp_params "%1.8e," du_ave_divout_p - 50.0)
    fprintf(fp_params "%1.8e," du_min_divout_p - 50.0)
    fprintf(fp_params "%1.8e," du_max_divout_p - 50.0)
    fprintf(fp_params "%1.8e," du(divout_n ave_vdda clip_start_divout_n clip_end_divout_n) - 50.0)
    fprintf(fp_params "%1.8e," du_ave_divout_n - 50.0)
    fprintf(fp_params "%1.8e," du_min_divout_n - 50.0)
    fprintf(fp_params "%1.8e," du_max_divout_n - 50.0)
    printf("Completed duty-cyle computations.\n")
    fprintf(fp_params "%1.8e," skew_ps(clk_p "rising" clk_n "falling" ave_vdda clip_start_clk_p clip_end_clk_p))
    fprintf(fp_params "%1.8e," skew_ps(clk_p "falling" clk_n "rising" ave_vdda clip_start_clk_n clip_end_clk_n))
    fprintf(fp_params "%1.8e," skew_ps(divout_p "rising" divout_n "falling" ave_vdda clip_start_divout_p clip_end_divout_p))
    fprintf(fp_params "%1.8e," skew_ps(divout_p "falling" divout_n "rising" ave_vdda clip_start_divout_n clip_end_divout_n))
    printf("Completed P/N skew computations.\n")
    fprintf(fp_params "%1.8e," rise_fall_ps(clk_p ave_vdda "rising" clip_start_clk_p clip_end_clk_p))
    fprintf(fp_params "%1.8e," rise_fall_ps(clk_p ave_vdda "falling" clip_start_clk_p clip_end_clk_p))
    fprintf(fp_params "%1.8e," rise_fall_ps(clk_n ave_vdda "rising" clip_start_clk_n clip_end_clk_n))
    fprintf(fp_params "%1.8e," rise_fall_ps(clk_n ave_vdda "falling" clip_start_clk_n clip_end_clk_n))
    fprintf(fp_params "%1.8e," rise_fall_ps(divout_p ave_vdda "rising" clip_start_divout_p clip_end_divout_p))
    fprintf(fp_params "%1.8e," rise_fall_ps(divout_p ave_vdda "falling" clip_start_divout_p clip_end_divout_p))
    fprintf(fp_params "%1.8e," rise_fall_ps(divout_n ave_vdda "rising" clip_start_divout_n clip_end_divout_n))
    fprintf(fp_params "%1.8e," rise_fall_ps(divout_n ave_vdda "falling" clip_start_divout_n clip_end_divout_n))
    printf("Completed transition time computations.\n")
    ; fprintf(fp_params "%1.8e," tpd_divout_p_rising)
    ; fprintf(fp_params "%1.8e," tpd_divout_p_falling)
    ; fprintf(fp_params "%1.8e," tpd_divout_n_rising)
    ; fprintf(fp_params "%1.8e," tpd_divout_n_falling)
    fprintf(fp_params "%1.8e," ave_ivdda_mA)
    fprintf(fp_params "%1.8e\n" ave_pwr_uW)
    printf("Completed supply current computation.\n")
    close(fp_params)
    else
    fp_params = outfile( fname "a")
    printf("sim_case = %d, sel_div_val = %.4f\n" sim_case sel_div_val)
    close(fp_params)
    else
    printf("Simulation case %d has NO input.scs file!!\n" sub_sim_case)
    if((print_internal_nodes_file == 1) then
    close(fp_int_params)
    else
    sub_sim_case = sub_sim_case + 1) ; close sub_sim_case loop
    sim_case = sim_case + sim_case_delta) ; close sim_case loop
    exit()
