  3. Command to check and save a schematic
  • Subscribers 152
  • Views 16849
prasadtammana
prasadtammana over 4 years ago
I'm writing a skill code to create a schematic, and then run schCheck(schCV) command to check and save the schematic. Then, schExtractStatus(schCV) command to find out if the extraction is dirty. The reason I'm using this command is to find out if the existing symbol needs to be updated. If the extraction status is dirty, I'm generating the symbol again.
The only problem I'm facing is, when schCheck(schCV) is executed, if there are any errors or warnings, a popup window is coming up to show the errors/warnings. I don't want this window to be open.
1. Is there a way to disable this popup window, because I don't want the user to see this error window.
2. Do we have any other command that does the extraction, without opening an error window.
Prasad
    Prasad,
    You should not get a popup with the errors and warnings when you do schCheck() - they should appear in the CIW. Can you share what the popup looks like?
    Which IC sub-version are you using? (getVersion(t) will return this)
  • prasadtammana
    prasadtammana over 4 years ago in reply to Andrew Beckett
    Thanks for your reply. Here is the snapshot of the popup. I have VDD_ANA2 in schematic and VDD_ANA in symbol. So, it's showing a popup with an error message to update the symbol.
    And I'm using "sub-version  IC6.1.8-64b.500.17 ".
    Prasad
    Andrew Beckett over 4 years ago in reply to prasadtammana
    Hi Prasad,
    I'm pretty certain that is not a standard part of Virtuoso that is giving that popup. I checked in the code and can't find it (possible that the wording has changed, but I don't recall ever seeing it, and certainly the wording doesn't look like how such a question would be phrased in our software). My guess is that it's done as part of a custom pre- or post- check trigger.
    Can you check what these two functions return? (type the functions in bold)
    schGetPostCheckTriggers()
    ("_schCICheck" "_schAMSPostCheck" "_schOIPostCheck" "_schRunCustomChecks")
    schGetPreCheckTriggers()
    ("_ciSchPreCheckTriggerForConNotes")
    I've shown the standard output that you normally get, so if there are other functions they may be local customisation. You may need to contact the creator of those functions to found out how best to disable the popup.
  • prasadtammana
    Yes, there are some custom functions that are being triggered. I'll check with my CAD team and see if there is a way to disable the popups.
    Prasad
  • prasadtammana
    prasadtammana over 3 years ago in reply to prasadtammana
    I found that there is a procedure that was added as part of Check and Save procedure that's showing the error window. If that particular procedure is disabled, the pop-up window won't show up.
    Do we have a command to skip running a particular procedure using skill? I want to enable the procedure again after my script execution is done, so that future check and saves will see this procedure running.
    Prasad
    Andrew Beckett over 3 years ago in reply to prasadtammana
    Hi Prasad.
    If you've identified the trigger with the schGetPostCheckTriggers()/schGetPreCheckTriggers() then you can do the following:
    schUnregPostCheckTrigger('funcName)
    ; do your work
    schRegPostCheckTrigger('funcName)
    There are equivalent functions with "Pre" instead of "Post" if was a pre-check trigger you were doing this with.
    For safety, you might want to do it this way:
    unwindProtect(
        ; do your work
    that means that it will always re-register the trigger even if there's an error somewhere in your code or it gets interrupted by ctrl-C (say).
