  3. Form like "Add instance" in schematic
  • Views 3269
Martinsh
Martinsh over 4 years ago
Dear Sir,
If we add an instances "port" from analogLib to a schematic window, many parameter fields appeared in the Form of  "Add instances". There is a field named "Display second sinusoid". If we check the field box, more parameter fields displayed under the "Display second sinusoid" field. If we cancel the check box, they disappear. How to realize this feature with skill code?
    Before spending time answering two possible meanings to this question, are you asking how to create a component that works this way with the create instance/edit properties forms (i.e. how to set up the CDF appropriately), or are you asking how to create a SKILL form which has similar functionality with fields that are hidden or not depending on the value of a checkbox on the form?
    I'd like to answer the question you really want the answer to rather than both...
  • Martinsh
    Martinsh over 4 years ago in reply to Andrew Beckett
    Andrew,
    Sorry for my unclear post. My question is the second one, how to control hidden/display of the fields by a checkbox.
    Martin
    Andrew Beckett over 4 years ago in reply to Martinsh
    Martin,
    Here's an example. It shows two ways - one using a boolean button with a callback to control visibility of fields, and the more modern way of using progressive disclosure (which behaves better in my opinion):
    procedure(CCFdisclosureExCreateForm()
        let((fieldA fieldB fieldC fieldD labelA labelB labelC labelD
                showFirstSet discloseSecondSet)
            fieldA=hiCreateStringField(
                ?name 'fieldA
                ?invisible t
            fieldB=hiCreateStringField(
                ?name 'fieldB
                ?invisible t
            fieldC=hiCreateStringField(
                ?name 'fieldC
            fieldD=hiCreateStringField(
                ?name 'fieldD
            labelA=hiCreateLabel(
                ?name 'labelA
                ?labelText "Field A"
                ?justification 'right
                ?invisible t
            labelB=hiCreateLabel(
                ?name 'labelB
                ?labelText "Field B"
                ?invisible t
            labelC=hiCreateLabel(
                ?name 'labelC
                ?labelText "Field C"
            labelD=hiCreateLabel(
                ?name 'labelD
                ?labelText "Field D"
            ; old school way of creating progressive disclosure - use
            ; a checkbox with a callback that controls visibility
            ; of fields
            showFirstSet=hiCreateBooleanButton(
                ?name 'showFirstSet
                ?buttonText " "
                ?callback
                    lambda((_field scope value)
                        scope->labelA->invisible=!value
                        scope->fieldA->invisible=!value
                        scope->labelB->invisible=!value
                        scope->fieldB->invisible=!value
            showFirstSetLabel=hiCreateLabel(
                ?name 'showFirstSetLabel
                ?labelText "First Set"
            ; modern way of doing it - using progressive
            ; disclosure
            disclosureSecondSet=hiCreateDisclosureTriangle(
                ?name 'disclosureSecondSet
                ?labelText "Second Set"
                ?onFields
                    list(
                        'labelC 'fieldC 'labelD 'fieldD
            grid=hiCreateGridLayout(
                'grid
                ?items list(
                    list(showFirstSetLabel 'row 0 'col 0)
                    list(showFirstSet 'row 0 'col 1)
                    list(labelA 'row 1 'col 0)
                    list(fieldA 'row 1 'col 1)
                    list(labelB 'row 2 'col 0)
                    list(fieldB 'row 2 'col 1)
                    list(disclosureSecondSet 'row 3 'col 0)
                    list(labelC 'row 4 'col 0)
                    list(fieldC 'row 4 'col 1)
                    list(labelD 'row 5 'col 0)
                    list(fieldD 'row 5 'col 1)
                    list('col_stretch 0 0)
                    list('col_stretch 1 1)
            hiCreateLayoutForm(
                'CCFdisclosureExForm
                "Disclosure Example"
                hiCreateVerticalBoxLayout(
                    'vbox
                    ?items list(
                        grid
                        list('stretch_item 1)
                ; get initial size roughly right to
                ; avoid scroll bars
                ?initialSize 300:160
    procedure(CCFdisclosureEx()
        ; avoid creating the form every time
        unless(boundp('CCFdisclosureExForm)
        ; uses inSkill so that this works if file has a .ils suffix
        hiDisplayForm(inSkill(CCFdisclosureExForm))
  • Martinsh
    Andrew,
    Thanks a lot.
    Martin
