  3. How to make a pin from terminal!
  • Subscribers 153
  • Views 10958
dogman4
dogman4 over 3 years ago
Hi all,
I have a schematic. I want an schematic’s bindkey. it can make a pin which name and direction same with the terminal by select the instance’s terminal and press this bindkey.
Now,I can only find the function:”scheHiCreatePin()” but can’t find the way to get selected terminal’s ID.
Can I get some help? Thank you guys in advance!
  • dogman4
    hello,anyone here,help pls
    Andrew Beckett over 3 years ago in reply to dogman4
    If this was urgent, you should contact customer support. This is not intended to be a substitute of that, and people reply here in their spare time (including those of us from Cadence who respond here). I had no spare time yesterday...
    If you've selected the pin on an instance, then you can retrieve information about it as follows.
    ; assuming just a single object is selected
    obj=car(geGetObjectSelectedSet())
    ; check that there is hierarchy in the selection
    when(cadr(obj)
      shape=car(obj)
      owner=car(cadr(obj))
      inst=car(owner)
      terminal=shape~>pin~>term
      terminalName=terminal~>name
      instTerm=car(setof(instT inst~>instTerms instT~>name==terminalName))
      shapeBBox=dbTransformBBox(shape~>bBox inst~>transform)
      printf("Selected terminal name %L net %L coord %L\n"
        terminalName
        instTerm~>net~>name
        shapeBBox
    Then if you're going to create a pin from SKILL, then using schCreatePin would probably make more sense rather than the "Hi" (Human Interface) version of the function.
  • dogman4
    dogman4 over 3 years ago in reply to Andrew Beckett
    hi,Andrew,thank for ur gentle reminders,i just ignore customer support.btw,skill code works,thank u  very much for spending time on helping me,Kissing heart
  • Tawna
    Tawna over 3 years ago in reply to dogman4
    If you are ignoring Customer Support, you are missing out working with quite a few excellent Application Engineers (some of them are active in the Cadence Community and write the Rapid Adoption Kits and Articles on Cadence Online Support)
