  3. Parameters Evaluating within the function
  • Subscribers 150
  • Views 8767
Tejaskill
Tejaskill over 3 years ago
Hi
I have a code, in which I am unable to evaluate a parameter within the function
procedure(mtest(X)
leSetEntryLayer(list("MX" "drawing"))
leSetAllLayerVisible(nil)
hiSetBindKey("Layout" "<Key>1" "mtest(\"1\")")
hiSetBindKey("Layout" "<Key>2" "mtest(\"2\")")
hiSetBindKey("Layout" "<Key>3" "mtest(\"3\")")
hiSetBindKey("Layout" "<Key>4" "mtest(\"4\")")
Can any one of you please help.
Teja.
    Change the line:
    to:
    leSetEntryLayer(list(strcat("M" X) "drawing"))
    or you wanted the function to accept a numerical argument, you could also use:
    leSetEntryLayer(list(lsprintf"M%d" X) "drawing"))
    but then you'd need to change your bindkeys to:
    hiSetBindKey("Layout" "<Key>1" "mtest(1)")
    Obviously your original function wouldn't work because there's no way that "X" would be evaluated when in the middle of a string.
