  3. how to get dc voltages and dc currents which annotated on...
  • Views 14793
how to get dc voltages and dc currents which annotated on schematic.
dogman4
dogman4 over 3 years ago
hi,all
there have  some functions to get  dc voltages and dc currents which annotated  on schematic.
below
    What are you actually asking? That's showing the DC operating voltages (Results→Annotate→DC Node Voltages) and the device operating points (Results→Annotate→DC Operating Points). You can also annotate the terminal currents (on the same menu, provided you've saved the currents), and through the View→Annotations menu in the schematic you can also choose to annotate both the DC voltages and currents at each device terminal.
    Clearly you're annotating something here, so have found a way to do this - so it's not clear what you're really asking. Given that there was no question in the title or the text of your post, it looks like you're just stating something - so it's very hard if you're just telling us you've done something (which is lovely, but probably not necessary to inform all the users on the forum), or whether there's really a question that you forgot to ask?
  • dogman4
    dogman4 over 3 years ago in reply to Andrew Beckett
    sorry andrew,thank you very much for your reply.My wrong
    I mean i want a skill function to get the value of annotated DC voltage(the DC voltages has been annotated) ,not how to annotate DC volatages on schematic.
    because there have mass data,so need function.
    Andrew Beckett over 3 years ago in reply to dogman4
    VDC("/netName") is the function you want. Or v("/netName" ?result 'dcOp)
  • dogman4
    thanks andrew,it‘s worked,you are so amazing
