  3. Pass current cellview ID to callback of a form
  • Subscribers 152
  • Views 10455
Martinsh
Martinsh over 3 years ago
Dear Sir,
I'd like to pass the current cellview ID (when the form displayed) to callback function of the form. So before the form is diaplayed, I use cv = geGetEditCellView() to get the current cellview ID, then I put it into the callback fucntion  ?callback "xpCreateInstArrayCb(hiGetCurrentForm() cv)"
When the form is created with hiCreateAppForm() function, it works well. But if the form is created with hiCreateLayoutForm() function, it can't work. When the callback is triggered, following error is reported:
*Error* eval: unbound variable - cv
Following are the skill code. Please help.
;;Case 1, works well
cv = geGetEditCellView(); Cellview when formXpCreateInstArray is created or displayed.
when( !boundp('formXpCreateInstArray) || (formXpCreateInstArray == nil)
formXpCreateInstArray = hiCreateAppForm(
?name 'formXpCreateInstArray
?formTitle "Create Instance Array"
?fields list(
hiCreateFloatField(
?name 'deviceSpacing
?value 60.0
?prompt "Spacing"
?unmapAfterCB t
?buttonLayout 'OKCancelApply
;?dialogStyle 'modal
;; Case 2, can't work
formXpCreateInstArray = hiCreateLayoutForm(
hiCreateFormLayout(
'formLayout
?items list(
hiCreateFloatField(
?value 60.0
?prompt "Spacing"
?unmapAfterCB t
?minSize 400:200
    Andrew Beckett over 3 years ago in reply to Martinsh +1
    Martin, Two choices. The first is to just call geGetEditCellView() in the callback: ?callback "xpCreateInstArrayCb(hiGetCurrentForm() geGetEditCellView())" which will then be the current cellView…
  • drdanmc
    drdanmc over 3 years ago
    What if you create the form and then store the cellview ID in the form as a property and have the callback then access the form property?  The callback would just take the form as the argument.
    -Dan
  • Martinsh
    Martinsh over 3 years ago in reply to drdanmc
    That's a good idea but I don't know how to store the cellview ID as a form property.
    -Martin
    Martin,
    which will then be the current cellView at the point you OK or Apply the form. If you want it to definitely be the cellView at the time you launched the form, then you can do:
    ;; Case 3, should work
      hiCreateFormLayout(
        'formLayout
        ?items list(
          hiCreateFloatField(
            ?value 60.0
            ?prompt "Spacing"
      ?callback "xpCreateInstArrayCb(hiGetCurrentForm() hiGetCurrentForm()->cv)"
      ?unmapAfterCB t
      ?minSize 400:200
    ; store property on form
    formXpCreateInstArray->cv=cv
  • Martinsh
    Martinsh over 3 years ago in reply to Andrew Beckett
    Andrew,
    It works well. Thanks!
    -Martin
