  3. oasisin to multiple destination libraries
  • Views 8466
eggnog
eggnog over 3 years ago
Hello!
I have an .oas with a large hierarchy and I want to oasisin the design, but have certain cells go to one destination library and other to another. (there are some frequently shared cells that I would like to have appear in a separate library)
I have the full list of cells that need to go into the separate library, but I don't see an easy way to have two destinations.
Is there an option I'm not aware of, or a way to do this with SKILL?
-E
    I don't think this is possible. I think that both the cellMap option and also if  you use the piCellNameMap SKILL function, it can only map to a different library if it is a reference library (the documentation is really unclear on this, but this seems to be what I've seen from experimentation). In other words, if you already have a few cells in other libraries that you want to re-use and ignore from the OASIS file, you can do that, but not split which destination libraries are used.
    This seems a reasonable request to me. so I think it would be worth contacting customer support (create a case after logging in) and requesting an enhancement. It's possible I've missed some existing capability, but if you try to use a cell map file and the library is not in the ref library list, it ignores it (and tells you that it's ignoring it).
