  3. Delete shapes under specific layers not working consist...
  • Subscribers 152
  • Views 11017
Delete shapes under specific layers not working consistently
SSR
SSR over 3 years ago
I wrote the following code (few portions coped from the support link here and i'm not an expert in scripting) to delete the touching/overlapping shapes with hilite/drawing9 layer. This works on some of the layers and seems to give the error mentioned below in certain cases. Please help me get this right.
CODE:
procedure(srDeleteShapesUnder()
cv=geGetEditCellView()
deleteLayer = leGetEntryLayer()
int = leLayerAnd(cv deleteLayer list("hilite" "drawing9") list("text" "drawing"))
ovlp = foreach(mapcar shp int
    dbProduceOverlap(cv shp~>bBox 0 deleteLayer)
ovlp2 = foreach(mapcar shp int
    dbProduceOverlap(cv shp~>bBox 0 list("text" "drawing"))
ovlps = apply('nconc ovlp)
ovlp2s = apply('nconc ovlp2)
foreach( shape ovlps
  dbDeleteObject( shape )
foreach( shape ovlp2s
);procedure
ERROR:
*Error* Value stack overflow has occurred for the second time (execution will be resumed at the most recent toplevel).
*Error* resume: resume can only be used within toplevel
    My guess is that you have some long lists and using apply('nconc ovlp) etc might be having some trouble (applying a function with a very large number of arguments in the order of 60000 or so can cause trouble).
    Perhaps try:
    ovlps = foreach(mapcan shp int
    ovlps2 = foreach(mapcan shp int
    instead. This will directly give you the concatenated lists.
  • SSR
    SSR over 3 years ago in reply to Andrew Beckett
    Thanks Andrew, the issue was the foreach loop itself. Modified it as following and it works now.
    ovlp1 = nil
    foreach( shp int
        ovlp = dbProduceOverlap(cv shp~>bBox 0 deleteLayer)
        ovlp1 = append(ovlp1 ovlp)
    Andrew Beckett over 3 years ago in reply to SSR
    This makes no sense - there's nothing wrong with the foreach loop. Your new implementation is potentially rather inefficient because it's using append - which will add to the end of the list, and is slow for large lists. Given that you are trying to build a flattened list, you might be better off swapping the order of the arguments to append, as ovlp will (in general) be the shorter of the two lists and so is quicker to reach the end. It would also be better to use nconc. Or better to use foreach mapcan!
    Given that the original error didn't make sense to me either - I wouldn't have expected the apply('nconc) to fail with a value stack issue - my guess is that the problem is actually elsewhere in your code and this part is just the piece that is finally hitting the value stack limit. If you use foreach with mapcar or mapcan, it actually transforms it from this:
    into this:
    ovlps = mapcan(
      lambda(shp) dbProduceOverlap(cv shp~>bBox 0 deleteLayer)
      int
    In other words, it's introducing a new (anonymous) function, and then calling that repeatedly for each element in the list. It might be this extra function that's pushing it over the limit, but that must be because of something going on above in the code (outside of what you've shared). That's the problem that needs fixing, not this - you are merely papering over the cracks otherwise.
  • SSR
    Andrew, appreciate the detailed reply, I've tried using the method that you have mentioned and it seems to work, but there is an issue.
    As per my usage, the script is supposed to delete all the dummy layers that are touching/overlapped with hilite/drawing9 layer and the size of the layout is about 14000x3500um. It seems like some of the dummy layers are removed and the rest are not. If I were to call the function again, it deletes some more, but not all. I'm not sure what's the limitation here.
  • SSR
    SSR over 3 years ago in reply to SSR
    Restarting the virtuoso fixed this issue, i'm not sure how though...
