  3. Looking for a SKILL script that will snap the centers of...
  • Views 5242
Looking for a SKILL script that will snap the centers of each instance to specific X and Y snap spacing
FormerMember
FormerMember over 3 years ago
Hi Cadence Community,
Good day
I am looking for a SKILL script that will snap the centers of each generated instance to a specific X & Y snap spacing.
Currently, I am doing this by selecting all the instances and then using quick align to snap all to my X & Y snap spacing.
Please see the screenshot below for the details.
Is this possible to be achieved using SKILL script?
Please help.
Thanks.
  • AurelBuche
    AurelBuche over 3 years ago +1
    Hi, Here is a script to snap selected instances to the closest grid point: (inScheme (let nil (defun get_closest_snap (x x_snap) "Return X closest snap value according to X_SNAP" (round x/(1.*x_snap…
    Andrew Beckett over 3 years ago in reply to FormerMember +1
    Berry, You can paste the code once into the CIW (or put in a file and load it), but to actually use it, you'd need to type: snap_instances() in the CIW. That's the name of the main function that…
  • AurelBuche
    (inScheme
    (let nil
        (round x/(1.*x_snap))*(1.*x_snap))
      (defun get_selected_instances nil
        "Return the list of currently selected instances"
        (setof obj (geGetSelectedSet) (equal "inst" obj->objType)))
      (defglobalfun snap_instances (@key (instances (get_selected_instances))
                                         (win       (hiGetCurrentWindow))
                                         (cv        (geGetWindowCellView win))
                                         (x_snap    win->xSnapSpacing)
                                         (y_snap    win->ySnapSpacing)
                                    @rest _args)
        "Snap the center of INSTANCES to the closest grid point"
        (foreach inst instances
          ;; Fetch instance center coordinates
          (destructuringBind (x y) (centerBox inst->bBox)
            ;; Calculate vector from center to closest snap point
            (let ((dx (get_closest_snap x x_snap)-x)
                  (dy (get_closest_snap y y_snap)-y)
              ;; Move instance
              (dbMoveFig inst cv (list (list dx dy) "R0" 1))
        );def
      );closure
    Hope this helps,
    Cheers,
    Aurel
  • FormerMember
    FormerMember over 3 years ago in reply to AurelBuche
    Hi Aurel,
    Thank you for the reply.
    I tried this skill by selecting one layout instance, then pasting the script to CIW and enter.
    But it didn't move the device.
    Not sure if my step is correct.
    Berry
    Berry,
    snap_instances()
    in the CIW. That's the name of the main function that's defined which does the actual work of snapping.
  • FormerMember
    FormerMember over 3 years ago in reply to Andrew Beckett
    Hi Andrew & Aurel,
    I finally understand how to use it.
    It is working as intended.
    Thank you very much for the help guys!
    Berry
