  3. *Error* if: too few arguments (at least 2 expected, 1 given...
  • Views 4237
*Error* if: too few arguments (at least 2 expected, 1 given) - ((length(match_result) == 1))
saurabh96
saurabh96 over 3 years ago
i have list as
rules_cadence = (list "LAY_TEST_1" "LAY_TEST_15" "LAY_DIODE" "LAY_DIODE_MISSING" "LAY_DIODE_AVAILIABLE")
i want that when i select "LAY_TEST_1" i get output as 1
when  "LAY_TEST_15" then 15
when ""LAY_DIODE" then DIODE
when ""LAY_DIODE_MISSING" then DIODE_MISSING
when "LAY_DIODE_AVAILIABLE" then AVAILABLE DIODE
AND WHEN I SELECT ALL THE OUTPUT WOULD BE  1,15,DIODE,DIODE_MISSING,AVAILABLE_DIODE
 i have written skill script but am getting an error-
rule get_value(string entry)
match_result = match(entry, "LAY_TEST_(\\d+)")
if(length(match_result) == 1)
return match_result[1]
else if(startsWith(entry, "LAY_DIODE"))
return "DIODE"
else if(startsWith(entry, "LAY_DIODE_MISSING"))
return "DIODE_MISSING"
else if(startsWith(entry, ""LAY_DIODE_AVAILIABLE""))
return "AVAILABLE DIODE"
else
return ""
endrule
result = buildString(foreach(item rules_cadence) get_value(item) ",")
how can i correct that issue
  • p94todorov
    p94todorov over 3 years ago in reply to saurabh96 +1
    Well, it is simply parsing the string using "_" as a parsing character, getting rid of the extra words that you are not interested in ("LAY" and "TEST" in your case) and they the return value is being…
  • p94todorov
    Something like this should return what you are looking for:
    yourStrignVar = <some of the options>
    returnVal = buildString(setof(str parseString(yourStringVar  "_") not(member(upperCase(str) list("LAY" "TEST")))) "_")
  • saurabh96
    saurabh96 over 3 years ago in reply to p94todorov
    Thanks p94todorov
    Can you explain in lil more detail?
  • p94todorov
    Well,
    it is simply parsing the string using "_" as a parsing character, getting rid of the extra words that you are not interested in ("LAY" and "TEST" in your case) and they the return value is being build from the remaining strings using again "_" to concatenate.
  • saurabh96
    Hello p94todorov
    thanks i got your point that parsing will eliminate the unnecessary field will give required o/p.
    but suppose in list rules_cadence = (list "LAY_TEST_1" "LAY_TEST_15" "LAY_DIODE" "LAY_DIODE_MISSING" "LAY_DIODE_AVAILIABLE") now
    when "LAY_DIODE_AVAILIABLE" is select from list then expected o/p should be this AVAILABLE DIODE, but in this case it will only eliminate LAY, how can GET O/P as AVAILIABLE_DIODE
    ALSO when we select all options from list how can we get o/p separated by , as buildstring
    as AND WHEN I SELECT ALL THE OUTPUT WOULD BE  1,15,DIODE,DIODE_MISSING,AVAILABLE_DIODE
