  3. [PCell] How do I Create a Label through script/coding in...
  • Replies 7
  • Views 5453
[PCell] How do I Create a Label through script/coding in a pcell?
Socks and Shoes
Socks and Shoes over 3 years ago
I tried the common ROD-functions like rodCreateRect or rodCreatePolygon but did not manage to figure it out.
Thanks for your help and greetings
  • p94todorov
    p94todorov over 3 years ago
    All you need should be a call to the dbCreateLabel API.
  • Socks and Shoes
    Hi guys,
    I need to create a label through coding/script in a Pcell.
    When I try to create a label for my polygon shape, the code is getting compiled without any errors, but the label does not appear.
            pcDefinePCell(
        list(ddGetObj("ex") "Pcell" "layout")
            (MET1 t)
    rodCreatePolygon(
                ?layer list("MET1" "pin")
                ?pts list( 0:0 1:0 1:1 1:0)
                ?pinLabel t
                ?pinLabelLayer list("MET1" "pin")
                ?pinLabelHeight 0.3
    Is there another way to create a Label through script in a pcell? Or did I something wrong?
  • Socks and Shoes
    Socks and Shoes over 3 years ago in reply to Socks and Shoes
    Ive made some mistakes in my posted code, but they are not related to my question. Heres the updated code:
    pcDefinePCell(
        list(ddGetObj("work_jw") "Pcell" "layout")
            (MET1 t)
    rodCreatePolygon(
                ?layer list("MET1" "drawing")
                ?pts list( 0:0 0:1 1:1 1:0)
                ?pinLabel t
                ?pinLabelHeight 0.3
    Andrew Beckett over 3 years ago in reply to Socks and Shoes
    I've combined your two posts. Please read the forum guidelines - they ask you not to post the same question to multiple forums.
    Peter gave you the answer further up the thread on one of your posts - see here.
  • Socks and Shoes
    Socks and Shoes over 3 years ago in reply to p94todorov
    Hey, I already tried that and the label really does appear in the original Pcell. But when I try to place the Pcell in a layout, the Rectangle is there, but the label is not. So I thought, that you need a ROD-Function for that. Did I do something wrong here?
    pcDefinePCell(
        list(ddGetObj("ex") "Label_Test" "layout")
            (Label t)
        let( ()
        dbCreateLabel(dbOpenCellViewByType("ex" "Label_Test" "layout") list("MET1" "pin") 1:1 "MyLabel" "centerCenter" "R0" "stick" 0.3)
        let( ()
            rodCreateRect(
                ?bBox list( 0:0 1:1 )
    You're creating the label in the wrong cellView. By re-opening the cellView with dbOpenCellViewByType, you're creating the label in the superMaster rather than the subMaster for this variant. Instead use pcCellView to specify the cellView for the current variant:
        dbCreateLabel(pcCellView list("MET1" "pin") 1:1 "MyLabel" "centerCenter" "R0" "stick" 0.3)
    I'm also not sure why you're surrounding each statement with an empty let? That's not necessary.
  • Socks and Shoes
    Socks and Shoes over 3 years ago in reply to Andrew Beckett
    Thank you so much Andrew! It works!
