  3. Get function code as S-expression
  • Subscribers 150
  • Views 10865
AurelBuche
AurelBuche over 3 years ago
Hi All,
In some of my tests, I need to make sure some function bodies are equal to expected S-expressions
I did a function to get the content of a function using `pp' but it has some limitations:
​(defun get_fun_code (fun "U")
"Return FUN definition as an S-expression"
;; Make sure function code is printed in Lisp style, not C one
(let ((top_fun_name '__get_fun_code_top_fun__)
(printinfix (status printinfix))
(port (outstring))
;; Make function global but hidden (considering top_fun_name is complicated enough)
(unwindProtect
(progn (sstatus printinfix nil)
(putd top_fun_name fun)
;; Print code to outstring and read it as S-expression
(funcall pp top_fun_name port)
(car (linereadstring (getOutstring port)))
;; Cleanup
(progn (sstatus printinfix printinfix)
(putd top_fun_name nil)
(close port)
My issue is: if the function contains specific objects in its body (functions, dbobject, etc.), they are printed as funobj:fun_name which `lineread' understands as (range funobj fun_name)
I can work with that but it is prone to error and I am sure pp is just a print of an existing function which I am not aware of (I guess it is private)
Cheers,
Aurel
    Andrew Beckett over 3 years ago +1
    Hi Aurélien, There's no underlying function that you can use. Many years ago (30 years ago in fact) getd() used to return the code - this was before the change to a Virtual Machine implementation though…
    Andrew Beckett over 3 years ago in reply to p94todorov +1
    Hi Petar, In SKILL++ mode all you need to do is: myFunc2=myFunc That would mean that myFunc2 is pointing to the function object that was stored in myFunc. If myFunc is redefined, then a new function…
    Hi Aurélien,
    There's no underlying function that you can use. Many years ago (30 years ago in fact) getd() used to return the code - this was before the change to a Virtual Machine implementation though. When that happened, the only way of de-compiling the VM code is to use pp() - so that's the only real approach - you have to special-case the situations such as you've seen.
  • p94todorov
    p94todorov over 3 years ago in reply to Andrew Beckett
    another question just crossed my mind when I read the above, but I don't want to open another thread:
    Is there a way to copy and de-reference a function object - e.g. attach it to another symbol.
    It would look like this:
    1) I have some function defined, for example: procedure(myFunc() ...
    2) I want to attach it somehow to another specifier name, say myFunc2
    3) When I call myFunc2() I would be looking for the same behavior as I've called myFunc() even if I re-define it later on and change it somehow.
    What I am looking for is an analogue for the copy function, but working with function objects instead of lists. Is this something possible?
    Petar
    Hi Petar,
    myFunc2=myFunc
    That would mean that myFunc2 is pointing to the function object that was stored in myFunc. If myFunc is redefined, then a new function object would be created and stored in the variable myFunc - leaving myFunc2 unaffected (that would continue to point to the original function object). As is usual with SKILL, variables are references to the object.
    In SKILL you can do this with:
    putd('myFunc2 getd('myFunc))
    which is a bit clunkier.
    Andrew Beckett over 3 years ago in reply to Andrew Beckett
    I meant to say that it's not doing a copy(), but since the function objects are immutable, a copy is unnecessary.
  • AurelBuche
    AurelBuche over 3 years ago in reply to Andrew Beckett
    I'll manage the `range' calls in my test cases then
    Thank you for your reply
    Cheers,
    Aurélien
  • p94todorov
    Thank you, Andrew!
    the getd seems to do what I was looking for and I can try to do what I had initially in mind.
    Much appreciated!
    Petar
