  3. Filter display and editable parameters of CDF, unbound cdfgForm...
  • Replies 7
  • Views 8926
Filter display and editable parameters of CDF, unbound cdfgForm error
FranzD
FranzD over 2 years ago
want to generate some variation values for a cell. For this I want to filter out at first which CDF parameters are editable and can be displayed. When I try to check the display condition of the CDF parameters I got an
*Error* eval: unbound variable - cdfgForm. And I dont understand why. My code is the following:
cdf = CCSgetCdfForCell(pdkLibName cell)
callFilt = CCSinvokeObjCdfCallbacks(cdf
?callInitProc t
params = cdf~>parameters
foreach(param params
if(param~>display then
   if(type(param~>display)=='string then
      display = evalstring(param~>display)
      );if display string
else
        ; display not definded
    display = t
);if display
If you have any suggestions how to do the wanted task in an another way or can help me fix my error I would be very glad.
Franz
  • FranzD
    So I manged to remove the cdfgFrom Error by setting cdfgForm = cdf (I used  setq(cdfgForm cdf) which should be the same)
    But I tought that the function CCSinvokeObjCallbacks() does this already? But why its not working then in the above code?
    Andrew Beckett over 2 years ago in reply to FranzD
    Hi Franz,
    Because the setting of cdfgForm (and cdfgData) is only done within the scope of the CCSinvokeObjCallbacks call. Once that returns, it is no longer set.
    I'm not sure which version of CCSinvokeObjCallbacks you're using (look at the SCCS information in the comments at the top), but the code can also call the display callbacks and return the results, using:
    CCSinvokeObjCallbacks(cdf ?callInitProc t ?callbackType 'display ?returnResults t)
    this will then return an assoc list of parameter name and result of the callback. There's a comment near the top of the file which mentions this (associated with version 1.17).
  • FranzD
    FranzD over 2 years ago in reply to Andrew Beckett
    I am using version 1.20 (last modified Nov 22).  I didnt understood the callbackType functionality. But now I do: So if I call CCSinvokeObjCallback with ?callbackType 'display and ?returnResults  t  I will get a list for each cdf parameter containing its name and the result of the display callback. I could then do the same with ?callbackType  'editable and sort out wich parameters have a t for each callback...?
    Also thanks for the reply,
    Franz
    Hi Franz,
    Spot on. You got it exactly right. I added this functionality relatively recently for an internal team who needed access to the editable/display information efficient for all fields.
  • FranzD
    Glad you did, its really usefull for my case. At last do you have a tip how to easly filter the parameters? Is it a good idea to use two foreach loops and check the values for both callbacks or is there an other way?
    Franz
    The comment at the top includes a setof() to filter just those which are true (that's only looking at (say) the display callback result). You could do:
    displayResult=CCSinvokeObjCallbacks(cdf ?callInitProc t ?callbackType 'display ?returnResults t)
    editableResult=CCSinvokeObjCallbacks(cdf ?callInitProc t ?callbackType 'display ?returnResults t)
    combinedResult=foreach(mapcar (disp edit) displayResult editableResult list(car(disp) cadr(disp)&&cadr(edit)))
    filtered=setof(pair combinedResult cadr(pair))
    fiteredParams=mapcar('car filtered)
    (I didn't test this, but it should be something like that to give you the parameter names which have both display and editable as non-nil)
  • FranzD
    Ok I tested it and it works. Thank you very much!
