  3. VIVA Transient Measurements Default Settings
  • Views 9244
Itay I
Itay I over 3 years ago
Hey, I'm trying to change the default settings in the transient measurements to measure 10% to 90% and also change the base line / top line.
I've added the following lines to my .cdsenv:
viva.trace threshold string "10_90"
viva.probe baseLine string "0.0"
But only the viva.trace seems to work. The viva.probe is generating the following warning message:
*WARNING* envSetVal: could not find tool[.partition] 'viva.probe'
Cadence version I'm using: ICADVM20.1-64b.
Itay
    Andrew Beckett over 3 years ago +1
    You'd need to use: viva.trace autoReferenceLines string "false" viva.trace baseAndToplineReferenceHint string "0.0,3.5" With autoReferenceLines set to true it trues to determine the base and top line…
    You'd need to use:
    With autoReferenceLines set to true it trues to determine the base and top line itself automatically; otherwise the hint values are used.
  • Itay I
    Itay I over 3 years ago in reply to Andrew Beckett
    Awesome, thanks
