  3. Printing CIW return value at cursor in layout window
  • Replies 7
  • Subscribers 150
  • Views 11611
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am looking for a code which can print the Return value of CIW at cursor in layout window
I am writing a code as follows but I have to see the return value of this code at the cursor point in layout window for every iteration.
hiSetBindKey("Layout" "Ctrl Shift<Btn4Down>" "pwi()")
hiSetBindKey("Layout" "Ctrl Shift<Btn5Down>" "pwd()")
procedure(pwi()
pwi=geGetSelSet()
foreach(h pwi
h~>width=h~>width+0.01
procedure(pwd()
pwd=geGetSelSet()
foreach(h pwi
h~>width=h~>width-0.01
Thanks in advance.
    I don't really understand what you're asking here. The return value of the pwi() and pwd() functions is the list of database objects which are selected.I'm not sure what you mean by "printing at the cursor in the layout window".
    Please explain clearly what you want to happen.
  • Tejaskill
    Tejaskill over 3 years ago in reply to Andrew Beckett
    Hi andrew
    I want to print the first value of the list returned by the functions pwi() and pwd() at the cursor point in layout window
    In most of the cases the value returned by pwi() and pwd() function is list with single float element. Now I want that float element to be printed at cursor point every time when I call the functions pwi() and pwd().
    Teja
  • RicardoGV1
    RicardoGV1 over 3 years ago in reply to Tejaskill
    If you mean visually, I've already asked support for a way to let us write on LEW CCR#2682366, the other thing that you could do meantime, is to create a text obj with the value you are getting from those fn's.
    you could use _leCreatePGText to create the text and here are two procedures to get the cursor position which I think hiGetPoint will be better for your case
    procedure(getCoordsScrn()
        prog(
                    pythonScript pythonScriptProcess pythonOutput tmp mouseXpos mouseYpos
                pythonScript = "python ~/Documents/Skills/Prueba/skill/to_be_approved/Skills/Mouse/Coordinates/MouseCord2.py"
                pythonScriptProcess = ipcBeginProcess(pythonScript) ;execute my python script
                ipcWait(pythonScriptProcess) ;wait for scipt to complete
                pythonOutput = ipcReadProcess(pythonScriptProcess) ;store script output
                if(ipcIsAliveProcess(pythonScriptProcess) == t then ;if child still exists
                    ipcCloseProcess(pythonScriptProcess) ;close child
                if(rexMatchp("Errno" pythonOutput) || rexMatchp("SyntaxError" pythonOutput) then
                    printf("\nERROR --> [getMouseCoordinates.il] A problem occured when executing the command: %L \n", pythonScript)
                    return(nil)
                rexCompile(" *")
                pythonOutput = rexReplace(pythonOutput " " 0)
                pythonOutput = parseString(pythonOutput "\n") ;format script output
                foreach(line pythonOutput ;step through each line of script output
                    rexCompile(" *")
                    line = rexReplace(line "" 0)
                    if(rexMatchp("c_int" line) == t then
                        tmp = parseString(line ")")
                        mouseXpos = atoi(nth(1 parseString(nth(0 tmp) "("))) ;store mouse X position
                        mouseYpos = atoi(nth(1 parseString(nth(1 tmp) "("))) ;store mouse Y position
                return(list(mouseXpos mouseYpos))
    procedure(getCoordsWin()
        hiGetPoint(hiGetCurrentWindow())
    Of course Andrew know more and maybe he could tell you something different.
    R. Gómez
    Andrew Beckett over 3 years ago in reply to RicardoGV1
    It's still not clear what you want. There is the ability to show info balloons with custom contents as you hover over a shape (see Options->Dynamic Display - you can even define a SKILL function to determine that content) - but you can't (as far as I know) show a temporary info balloon as you execute a function. I guess you could create a hilight label (geCreateHilightSet and then geAddHilightLabel) and use a timer (hiRegTimer) to turn off the display of it after a period of time (probably removing the label or destroying the hilight set). That could be added at the current point using something like hiGetPoint().
    Your pwi/pwd functions don't return numbers; I assume you want them to show the new width. Anyway, I'll leave this as an exercise for you to try out.
  • Tejaskill
    Hi andrew,
    Thanks for the reply I have written a code based on your inputs I have acheived what I want
    But There is an issue with my code the highlighting labels are not removing with geDeleteHilightSet() but the hilight labels are removed by geDeleteAllHilights() >>>>> but with this function the highlights created by MarkNet are also being removed could you please suggest me a solution.
    Below is the code I have written based on your inputs
    procedure(pwi()
    tk=geGetEditCellView()
    pwi=car(geGetSelSet())
    rw=pwi~>width=pwi~>width+0.01
    rw1=artMakeString(rw)
    ln=pwi~>layerName
    lp=pwi~>layerPurpose
    hs=geCreateHilightSet(geGetEditCellView() list(ln lp) nil)
    hs~>enable=t
    hp=hiGetPoint(hiGetCurrentWindow())
    geAddHilightLabel(hs hp rw1 "centerCenter" "R0" "stick" rw nil)
    hiRegTimer("geDeleteAllHilightSet(tk)" 5)
    procedure(pwd()
    pwd=car(geGetSelSet())
    rw=pwd~>width=pwd~>width-0.01
    ln=pwd~>layerName
    lp=pwd~>layerPurpose
    hs~>enable=t
    Teja.
    Andrew Beckett over 3 years ago in reply to Tejaskill
    Teja,
    Rather than deleting all hilight sets you should delete the specific hilight set you created. I modified your code to achieve this, and at the same time got rid of all the global variables; it stores the hilight set as a property on the window so that it can be retrieved easily later for deletion:
    procedure(pwCommon(increment)
      let((tk pwi rw rw1 ln lp hs hp win)
        win=hiGetCurrentWindow()
        ; delete hilight set if already exists in case increment/decrement
        ; is done before timer has kicked in
        pwDeleteHilight(win)
        rw=pwi~>width=pwi~>width+increment
        ln=pwi~>layerName
        hs~>enable=t
        ; store the hilight set as a property on the window to
        ; retrieve later for deletion.
        win~>pwCommonHS=hs
        hp=hiGetPoint(win)
        hiRegTimer(lsprintf("pwDeleteHilight(window(%d))" win->windowNum) 5)
    ; retrieve hilight set from the window, and delete if valid
    procedure(pwDeleteHilight(@optional (win hiGetCurrentWindow()))
      when(geIsValidHilightSet(win->pwCommonHS)
        geDeleteHilightSet(win->pwCommonHS)
    procedure(pwi()
      pwCommon(0.01)
    procedure(pwd()
      pwCommon(-0.01)
  • Tejaskill
    Thanks Andrew
    Now it works perfect.
    Best regards,
    Teja
