  3. how to adjust pin to pin distance when create schematic...
  • Views 10412
how to adjust pin to pin distance when create schematic by pin list
KC Lee
KC Lee over 3 years ago
I create schematic by pin list. The pin to pin distance is larger than what I need. How can I adjust that pin to pin distance?  I like to put pins side by pin to connect another cell. The distance should match symbol pin distance.
    It appears that the pin spacing is set to 0.25 or if there's a property on the view (in the property bag), then it will use 4 times that (the property being xSnapSpacing). Unfortunately it seems you have to create the schematic first just to keep everything happy:
    cv=dbOpenCellViewByType("opamp090" "testpincreate" "schematic" "schematic" "a")
    bag=dbOpenBag(ddGetObj("opamp090" "testpincreate" "schematic") "a")
    bag~>xSnapSpacing=0.03125
    dbSaveBag(bag)
    dbCloseBag(bag)
    ; do not close the cellView as otherwise it will get deleted - perhaps should just do dbSave(cv) first?
    ;dbClose(cv)
    then you can do the pin creation for the schematic. Not sure this is a particularly sustainable approach, so it might be best to request an enhancement to control the pin spacing default with a cdsenv variable, say.
