  3. Create routing blockage
  • Views 10628
mattab
mattab over 3 years ago
Can anyone let me know function to create a routing blockage  just like "dbCreatePin" for a pin
regards
    dbCreateLayerBlockage(). The third argument would be "routing".
    I suggest you use the command-line cdsFinder command, or type startFinder() in the CIW. Then search for "Blockage" - you'd have found the functions then, and the "more info" button will take you to the full documentation for the function.
  • mattab
    mattab over 3 years ago in reply to Andrew Beckett
    thank you Andrew
