  3. Error when using 'sevActiveSelectedAna()'
  • Views 1824
Upasana Acharya
Upasana Acharya over 3 years ago
I want to extract the analyses that are selected (regardless if they were enabled or not) under each test in maestro ADE Assembler. Hence, I decided to use 'sevActiveSelectedAna()' and 'sevNonActiveSelectedAna()'. However, I get the following error message in CIW:
   """ *Error* slotValue: no such slot - axlsession in class spectre_session. Valid slot names: (icrpFreeMode isSmIcCorModelSpec deviceParamList swiftHeartBeatCallback swiftHeartBeatInstanceCount swiftHeartBeatCellCount name parent scopeStore scope valid modified data access children initFunc state parentSession netlistObject masterOptionTable oppointSaveInfo aliasfd inPOLONameMapDBGenFlow spectreXFlag preserveInstFlag netlistMasterOptions) """
Following is my code:
s1 = axlGetWindowSession()
session = axlGetMainSetupDB(s1)
tTests = axlGetTests(session)
foreach( t tTests
testSession = axlGetToolSession(s1 r)
asiSess = asiGetSession(testSession)
aE = sevActiveSelectedAna(asiSess)
aNE = sevNonActiveSelectedAna(asiSess)
printf("%L\n" aE)
printf("%L\n" aNE)
);foreach
Can anyone else figure out the issue?
Thank you!
  • Upasana Acharya
    Sorry, need to make a correction: testSession = axlGetToolSession(s1 t)
    Andrew Beckett over 3 years ago in reply to Upasana Acharya
    There are several things wrong with the code:
    1. The loop variable can't be called t because that's reserved (to mean true) and would give an error if you did that. So your correction can't be right either
    2. You would need to do foreach(test cadr(tTests) ...) or you would need to have tTests=cadr(axlGetTests(session)) for the loop to be correct
    3. The argument to sevActiveSelectedAna/sevNonActiveSelectedAna needs to be a sevSession not an asiSession - so in your case, it would need to be the variable testSession not asiSess
    However, even with this, it doesn't work (it doesn't fail with an error, but it doesn't work). I don't believe these functions work properly in Explorer/Assembler - looking at them they return t/nil (rather than a list of analysis objects) if the session is for Explorer; for Assembler I think they always return nil because it's looking for an ADE XL test editor type list box to find the selected objects, and that doesn't exist in Explorer or Assembler.
    Even with ADE XL this strikes me as being of questionable value (I found only a single reference to sevActiveSelectAna in any case or CCR over the years),  because you could only select objects for a single test at a time.
    So my question is (before I report these functions as being broken and suggest their retirement or at least indication that they are only useful for ADE L or an ADE XL test editor) what do you mean by "selected"? Are you trying to find all the analyses that are present in the test (whether enabled or not), or are you trying to determine which have been selected (i.e. click and shift-click a range) in the data view assistant? If so, why do you need this?
