  3. How to Fetch all the instances in from a Top cell Hierarchy...
  • Views 11338
How to Fetch all the instances in from a Top cell Hierarchy?
Sandeep Kailasa
Sandeep Kailasa over 3 years ago
I am able to fetch the cell details from the Top cell. But When I am recursively calling the function to print parameters of Cells, then I am getting instances of instance  as nil. If i am calling the celldetails function below, I am unable to get the instances details as it is not considered as an top cell. Can someone help me with this.
Thanks ,
Sandeep
Skill Code:
cellinstances=list()
procedure(celldetails(cv)
printf("\n\nHello Sandeep Kailasa\n")
printf("Top CELL name is :%L\n" cv~>cellName)
printf("Cell View Type is %L\n" cv~>cellViewType)
printf("\nInstances of Cell %L are : %L\n" cv~>cellName cv~>instances~>cellName)
foreach(inst cv~>instances
printf("Purpose of Instance %L is %L\n" inst~>cellName inst~>purpose)
case(inst~>cellName
("pmos4"
printf("Instance name is : %L\n" inst~>cellName)
printf("Instance %L-%L connected to Pins: %L\n" inst inst~>cellName inst~>conns~>net~>name)
printf("Instance %L-%L connected to Terminals: %L\n" inst inst~>cellName inst~>conns~>name)
("nmos4"
(;rexMatchp("pin$")
"iopin"
printf("Instance is a iopin %L\n" inst)
"opin"
printf("Instance is a opin %L\n" inst)
"ipin"
printf("Instance is a ipin %L\n" inst)
(t
when(!memq(inst~>cellName cellinstances)
cellinstances=cons(inst~>cellName cellinstances)
printf("\n\nInstance name is : %L\n" inst~>cellName)
printf( "\n............Calling the function .........\n")
celldetails(inst)
printf("\n...........Returning from Function..............\n\n\n")
);when
);case
);foreach
);procedure
    Andrew Beckett over 3 years ago +1
    I reformatted the code (it is very hard to follow without indentation) and fixed various issues. The main things I fixed where: celldetails() was being called recursively with the instance id rather…
  • Sandeep Kailasa
    Sandeep Kailasa over 3 years ago in reply to Andrew Beckett +1
    Thanks for your reply Andrew.. I am using dbOpenCellViewByType(inst~>libName inst~>cellName "schematic"), then its working fine for me. Can I know how to change any of the parameters of the cells/ instances…
    Andrew Beckett over 3 years ago in reply to Sandeep Kailasa +1
    OK, that seems a more complicated solution than just using dbGetAnyInstSwitchMaster (if you want to restrict it just to schematic views, you could pass "schematic" rather than "schematic cmos.sch" - the…
    1. celldetails() was being called recursively with the instance id rather than the cellView id of the switched view (even if you'd have passed inst~>master it would have then been traversing the symbol; I am assuming here you're traversing a schematic hierarchy)
    2. You've used memq to compare a string against a list of strings - you should never use memq with strings (the documentation says this too, I think)
    3. I changed the global variable cellinstances to instead be an optional argument to the function and the return value of the function - this avoids the need for any global variables
    Here's the updated version:
    ;; remove need for cellinstances to be global by having optional argument
    ;; and returning the cellinstances list from the function
    procedure(celldetails(cv @optional cellinstances)
     let((master)
             cv~>cellName
        case( (inst~>cellName)
          ("pmos4"
                  inst
                  inst~>cellName
                  inst
                  inst~>cellName
                  inst~>conns~>name
          ("nmos4"
                  inst
                  inst~>cellName
                  inst
                  inst~>cellName
                  inst~>conns~>name
          (;rexMatchp("pin$")
           "iopin"
          ("opin"
          ("ipin"
          (t
           ;; do NOT use memq with strings. Change to member
           when(!member(inst~>cellName cellinstances)
             cellinstances = cons(inst~>cellName cellinstances)
                    inst
                    inst~>cellName
                    inst
                    inst~>cellName
                    inst~>conns~>name
             ;; you need to pass the master not the instance id. Also, if it's
             ;; a schematic, you'll need to view-switch into the schematic.
             ;; only call the function recursively if there is a switch view
             master = dbGetAnyInstSwitchMaster(inst "schematic cmos.sch")
             when(master
               printf("\n............Calling the function .........\n")
               cellinstances=celldetails(master cellinstances)
            ) ;when
         ) ;case
       ) ;foreach
      ;; return the updated list of cells already visited
      cellinstances
      ); let
     ) ;procedure
  • Sandeep Kailasa
    I am using dbOpenCellViewByType(inst~>libName inst~>cellName "schematic"), then its working fine for me. Can I know how to change any of the parameters of the cells/ instances in the above code?
    Sandeep
    OK, that seems a more complicated solution than just using dbGetAnyInstSwitchMaster (if you want to restrict it just to schematic views, you could pass "schematic" rather than "schematic cmos.sch" - the view list was just an example), but it should work.
    What do you mean by "how to change any of the parameters of the cells/instances"? What are you trying to do? Your question is rather vague - if you want to change parameters on an instance, you'd set the properties on the instance when you are accessing it, but your intentions are rather unclear... rather than me trying to guess what you might actually mean, it would be better if you explained it clearly yourself.
  • Sandeep Kailasa
    Thanks Andrew,
    The thing is I am able to get and access all the cells/instances in the Hierarchy . Now I have to change any of the parameters of the cell like changing  its CellName or net name or pin or Instance Name or any other parameters of the cell. I have to do the above mentioned changes in my Skill Script. Is there any Function to do that. Will the Setq function work for this.
    Sandeep
    Sandeep,
    setq() is just the functional equivalent of "=" (i.e. assignment). I doubt this is what you want. So:
    setq(a 5)
    is the same as
    a=5
    If you want to set a property on an instance, use either:
    inst~>w="2u" ; assuming the property was called w
    dbReplaceProp(inst "w" "string" "2u") ; you have to get the type right if you use this approach
    (that said, the type of the value has to be correct anyway).
    To change the cellName, you have to replace the master:
    newMaster=dbOpenCellViewByType("theLib" "theCell" "symbol")
    inst~>master=newMaster
    With most PDKs you would normally find that changing parameters would require CDF callbacks to be called to ensure everything is consistent (unfortunately; I've written much about this before - see The dangers of CDF callbacks) - using something like this would help too: How to call CDF callbacks procedurally from SKILL to update CDF parameters?
