  3. virtuoso printing numerous warnings in CIW causing performance...
  • Views 1588
virtuoso printing numerous warnings in CIW causing performance issues -- "*WARNING* Failed to delete XXXXX" -- each time a schematic view is being saved
MFahmy
MFahmy over 3 years ago
I am running a SKILL code which does some modifications on the schematic followed by a check and save of the schematic
the code iterates over the same schematic and each time it updates some parameters,  followed by schCheck(cv) then dbSave(cv)
and finally netlisting the updated schematic.
The problem I am seeing is that every time the dbSave(cv) is called, I get a list of warnings in the CIW as shown below, and with every iteration in the loop, the number of printed warnings is incremented, so after a couple of hundreds of iteration it seems virtuoso needs sometime to print the complete list of warnings and netlisting gets significantly slower
what maybe the root cause of such warnings ?
one thing I noticed, that manually modifying the params and doing a check an save by clicking in the schematic editor doesn't reproduce the issue, it is only when it is done through skill commands
(ScanOnSave): The cellView LIBXX/CELLXX/schematic_temp is managed by ICManage
Successfully saved backup ofLIBXX/CELLXX/schematic_temp on Feb 17 22:11:59 2023
*WARNING* Failed to delete 1676653584
*WARNING* Failed to delete 1676653677
*WARNING* Failed to delete 1676654314
*WARNING* Failed to delete 1676654799
*WARNING* Failed to delete 1676654800
*WARNING* Failed to delete 1676654950
virtuoso : ICADVM20.1-64b.500.28
Spectre: sub-version  21.1.0.546.isr13
Fahmy
    Hi Fahmy,
    The first message (ScanOnSave) looks as if it is coming from the code at: <ICinstDir>/tools/dfII/etc/tools/cdba/cdsScanOnSave.il which is presumably being used in your environment. I don't see any message about "saved backup" in that code, so I don't think the second message is from that - and I can't find any references to "Failed to delete" in that format - so that may be due to either your code or the customisation code in your environment.
    I suggest you contact customer support as this probably needs some detailed debug looking at your setup.
