  3. Issue when making constraint in constraint groups(cstCreateConstraint...
  • Views 1612
Issue when making constraint in constraint groups(cstCreateConstraint())
knowledgeseeker
knowledgeseeker over 3 years ago
Hi.
I want to make constraint in constraint groups.
below is my SKILL code
cv = dbOpenCellViewByType("myLib" "myCell" "myView" "netlist" "w")
cg = cstCreateConstraintGroupIn(cv "CustomCG" "userdefined")
cstCreateConstraint(cg "myConstraint" nil nil)
and CIW gives me
*WARNING* cstCreateConstraint: Constraint def myConstraint is not defined in constraint registry.
What can I do in this situation.
I think defining constraint's defName is needed.
    cstCreateConstraint only supports built-in OA constraints (such as those in the tech fie such as minWidth, minSpacing). For custom constraints see How to define custom or user defined constraint type in virtuoso. and then you need to use ciConCreate to create the constraint.
