  3. Enter function bindkey for a specific function.
  • Subscribers 150
  • Views 11730
Tejaskill
Tejaskill over 3 years ago
Hi all.
I am looking for a code which can set enter function bindkey for a particular function like in below example
I have written a bindkey enter function as below.
hiSetBindKey("Layout" "Ctrl<Key>a EF" "a()")
But this should be executed only when I am using Quickalign function in layout.
Is there any way to achieve this?
Thanks, in advance.
  • skillUser
    skillUser over 3 years ago
    One way to achieve this is inside your 'a()' function, something like:
    procedure(a()
      when(hiGetCurrentCmd() == "Quick Align"
       ... insert the rest of your code here ...
      ); when
    ); procedure a
    There is another function "hiInEnterFun()" but this returns 'enterPoints when inside Quick Align (and possibly other values, but this is what I saw when playing around).
    Hopefully this is what you are looking for?
    Best regards,
    Lawrence.
  • Tejaskill
    Tejaskill over 3 years ago in reply to skillUser
    Hi Lawrence
    Thanks for the reply this is exactly what I was looking for
    And I have two more questions.
    1. I want to assign two functions i.e. leHiQuickAlign() and Invoking a form by using hiDisplayForm(xyz) to a BINDKEY
    Is there any way can we achieve this
    2.Can we get more information BINDKEY ENTER FUNCTIONS and ENTER POINTS
    Teja
  • skillUser
    skillUser over 3 years ago in reply to Tejaskill
    Hi Teja,
    For the first item you can make your bindkey setting something like the following:
    hiSetBindKey("Layout" "<Key>a" "hiEnqueueCmd(\"hiDisplayForm(xyzForm)\") leHiQuickAlign()")
    For the second item the documentation has all the information that you should want, all of the enterFunctions, for example, are there (e.g. enterBox, enterPoint, enterPoints, enterPolygon ...) - the doc hierarchy is SKILL -> SKILL Language -> Cadence User Interface SKILL Reference -> User Entry Functions and the file for this is <install_dir>/doc/skuiref/chap12.html This should answer your question.
    Best regards,
    Lawrence.
  • Tejaskill
    Thanks for the reply Lawrence
    Best regards,
    Teja
