  3. Behavior of case() for boolean values
  • Views 9482
Paul Staerke
Paul Staerke over 3 years ago
I guess this question was already asked several times, but I could not find a fitting post.
To handle booleans with case(), the values must be specified differently than for normal constants due to the special meaning of 't' and 'nil'. The documentation gives an example, where these cases are given as single-element lists. However, this does not work for me. Here an example (the case code is directly from the manual)
foreach(mapcar myBool '(nil t (nil) (t) 1)
  case( myBool
    (nil 'never) ; this will never match, it is a list of no keys
    (( nil ) nil) ; matches nil
    (( t ) t) ; matches t
    (t (error "Expected t or nil"))
);foreach
=> (never t t t t)
However, when I modify the code this way, it works
  case( myBool
    ('nil nil) ; matches nil
    ('t t) ; matches t
    (t "other")
);foreach
=> (nil t "other" "other" "other")
Is there maybe something wrong with my setup or environment settings?
Best regards
Paul
    Hi Paul,
    The example is not really correct. In the initial example (based on the document), the nil clause does match (so it's misleading to say that it will never match!). The (nil) clause won't match because the nil has already been caught by the previous clause. The (t) clause serves as a default in the same way as t so it always matches if it gets that far (I'm not convinced this is correct, but we probably can't change it safely without breaking code that depends on this behaviour).
    The case function can match t if the clause is a list containing t and something else. So for example if the clause was (5 t) it would match either 5 or t. The reason that using 't works is that this is the same as (quote t) which means that either quote or t matches - as can be seen here:
    foreach(mapcar myBool '(nil t (nil) (t) 1 quote)
      case( myBool
        (nil "nil") ; matches nil
        ('t "t") ; matches t or quote
        (t "other") ; matches anything else
    );foreach
    which returns:
    ("nil" "t" "other" "other" "other" "t")
    Hope that helps a bit!
  • Paul Staerke
    Paul Staerke over 3 years ago in reply to Andrew Beckett
    Hello Andrew,
    thank you for your quick answer. This behavior is a bit confusing. Maybe this can be fixed in the manual in the future? As a solution, I am using now (t t) as case condition, which also works and only matches t.
    Best regards
    Paul
    Andrew Beckett over 3 years ago in reply to Paul Staerke
    Hi Paul,
    Yes, I'll request an update to the documentation tomorrow when I'm in the office (I'd planned to do this anyway).
