  3. Merge Shapes -- cycle through 'Scope' options
  • Views 1217
iDoLayout
iDoLayout over 3 years ago
I want to assign a bindkey to cycle through the 'Merge Shapes' options.  In the documentation I only see a way to toggle 'Merge Shapes' on and off with 'mergeEnable' -- can't see a way to access the 'Scope' options of 'Pcells, Except current, All'.
I'd like to write a procedure to switch through 'mergeEnable nil' -> 'mergeEnable t w/ Pcells scope' -> 'mergeEnable t w/ Except current scope' -> 'mergeEnable t w/ All scope' -> back to 'mergeEnable nil'
Thanks.
    I just threw together a function which cycles through the options. Hopefully you can see how this works:
    procedure(CCFcycleMergeShapes(@optional (win hiGetCurrentWindow()))
      letseq((
        (mergeEnable win->mergeEnable)
        (mergeScope mergeEnable && win->mergeScope)
        ; Using a list of mergeEnable and mergeScope settings, find the
        ; matching entry in the sequence and then use the next entry
        ; to update the window properties
        destructuringBind(
          (@optional nextEnable nextScope)
          cadr(member(
            list(mergeEnable mergeScope)
            list(list(nil nil) list(t "pcells") list(t "except current")
              list(t "all") list(nil nil))))
          win->mergeEnable=nextEnable
          win->mergeScope=nextScope
          ; Return the new values in case it's useful!
          list(nextEnable nextScope)
